Sponsored by: GEM Motorsports
And The Build Begins!
Old 09-30-2015, 11:32 PM
Andy@A&ACorvette
Platinum Supporting Vendor
Andy@A&ACorvette's Avatar
Default And The Build Begins!
Started the teardown yesterday afternoon. Heads off, cradle out, cam swapped, oil pan and timing cover back on in about 8 hours.
Heads are being machined to accept an LT1 intake manifold, a little porting and have the BTR springs installed.
The cam is a "baby" 220-230 -117 so as not to upset drivability and also to work with the stock converter. The cam change is mostly for the larger fuel pump lobe anyway.
LS7 lifters and trays are installed along with the Katech valley cover.
American racing 2" headers are being coated prior to install.
The Eaton Supercharger is no more. An A&A System with a YSi head unit will be replacing it.
An Alky Control system is being added to cool things down and add some much needed Octane.
I have a Halltech intake on it so I'm going to cut off the MAF tube and remake it with 4" aluminum tube to adapt to the YSi.
I'm thinking we should be around 18 # boost, but that is a guess at this point. Should make some serious power.
Looking forward to hearing that "Big Bubba" Blowoff valve scare some unwary people.
Notice the brackets I made to hold the engine up when the cradle is removed? They make it very easy to work on the underside and front of the motor.
The last picture is a picture of my '14 C7 with my standard system on it just so you can see what it will look like (except for a much bigger head unit).
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old 09-30-2015, 11:42 PM
sam90lx
sam90lx's Avatar
This should be a Beast! Just noticed you guys moved up near me, no more Oxnard?
Old 09-30-2015, 11:48 PM
MikePD
MikePD's Avatar
bad *** andy!!!
Old 09-30-2015, 11:49 PM
Andy@A&ACorvette
No. I've been in this building over 11 years. Technically were are in "Unincorporated Ventura County" They just call it Oxnard because it's close by.
Old 10-01-2015, 12:24 AM
Trawicked
Trawicked's Avatar
What intake did you use to replace the stock supercharger?
Old 10-01-2015, 01:33 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
andy.... gonnna make more power than the tbss???? lol
Old 10-01-2015, 01:57 AM
Trawicked
Trawicked's Avatar
Scratch my question, I Re'read it and got my answer. Will you be selling the heads as such?
Old 10-01-2015, 02:12 AM
SBCGENII
SBCGENII's Avatar
It says LT1 in his post.
Old 10-01-2015, 03:26 AM
DLC7
DLC7's Avatar
Something beautiful about that very first picture.
Old 10-01-2015, 01:11 PM
jbsblownc5
Support Corvetteforum!
jbsblownc5's Avatar
2017 C5 of the Year Finalist
St. Jude Donor '08
Very Cool Andy! looking forward to the results on this project...
Don't forget to see what she does with a little Torco!
Good luck with it!
Old 10-01-2015, 01:47 PM
tail_lights
tail_lights's Avatar
Very cool, in for results!!!
Old 10-02-2015, 07:40 PM
Andy@A&ACorvette
Default Going back together
We couldn't work on it at all yesterday. Customers come first!
Getting the heat exchanger, trans cooler, etc. out of the car took a lot of time. I think we'll relocate the trans cooler to where the heat exchanger was.
Evidently LT4 takes different valve springs than LT1 so I couldn't put the heads back on. Springs will be here Tuesday.
I wanted to make sure my regular C7 bracket would fit without issue so we just mocked it up. It looks like it will just be a standard C7 install from this point on.
So we have about two full days into it so far and I think we're over halfway there.
Old 10-02-2015, 08:03 PM
tail_lights
Because Race Version!!!
Old 10-02-2015, 08:54 PM
nullpointer
nullpointer's Avatar
Awesome, subd!
Old 10-02-2015, 10:12 PM
ACEINRS
Cruising
ACEINRS's Avatar
subscribed
Old 10-03-2015, 01:19 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Major beast Andy sweet C7Z ! Can't wait for the numbers!
Old 10-03-2015, 01:35 AM
JustinStrife
JustinStrife's Avatar
I want a blade silver version of this car(with the black stripe) to go along with my '99 FRC.
Subscribing to Andy's magic!
To And The Build Begins!
Old 10-03-2015, 11:50 AM
0HorsePowerAddicts
Former Vendor
HorsePowerAddicts's Avatar
Looks awesome Andy.
Old 10-09-2015, 11:08 AM
0NORCAL-SS
Former Vendor
NORCAL-SS's Avatar
Sooooo andy.
We have ProCharger
22 psi
Cam
Meth
998/776
Are you trying for 1000/1000 lol
Yes im adding Fuel to fire.... ha. Looking forward to what your set up makes at 18 psi.
Old 10-09-2015, 11:20 AM
Trawicked
Trawicked's Avatar
Originally Posted by NORCALSS
Sooooo andy.
We have ProCharger
22 psi
Cam
Meth
998/776
Haha LOL
Quick Reply: And The Build Begins!
