Viper VS Z06
Please don't spread misinformation to make yourself feel better.
Greg, I posted that because Im not sure what slip was against you. they don't have the car names on there. I have 10 slips and I guess we ran earlier. Later in the day I 149 against a 152 and I thought that was you. Also my highest in the day was 155 starting slightly above 60 (the supercharged grey M3 went hard out of the flag). What I should do next time as put the slip infront of the camera after every race I know whats what. This time I just stuffed em in my pocket. At the end of the day my times did improve a good bit with confidence in no lift shifting but Greg also said his did I believe. In any case regardless of speed because I don't have the slips any longer, the viper's 4th gear will win every time. I don't know how much that tune really adds but the viper pulls harder in 4th than the Z06. I feel no way to match that without a mod advantage. In the lower gears as you can see the cars are dead even until the moment I began the shift to 4th and its over.
True but it walked away in 4th pretty strong. Like I said above I don't know what that tune adds but nineball claimed 30-40whp. Even without that I think the gearing is stronger in the viper and the outcome would have been the same but maybe closer. Guys I know there is the war between these 2 cars, on a road race course I don't know that the viper will be faster, but in this event the viper is just a faster car.
Agreed but the viper was a stick also. I would have to say the race as "pretty" fair. Yes he had a tune but that 30-40 didn't win the race. For the sake of argument, lets say the viper was stock and my times were based on the later in the day with no lifting (which is great BTW, I didn't trust it at fist) and I had removed my aero, I still think the viper wins but maybe by a nose. it would be a damn close race. As if it already wasn't it. I was expecting more distance in 4th then the outcome was. Thing pulls hard up top. The Z didn't seem to have that same strength in 4th as it did in 3rd. Trust me I wanted that win but it not going to happen stock to stock in that situation (again I don't believe the tune won that race)
I do a lot of organized roll events, trap speeds can vary quite a bit due to many factors. You can't really compare your various trap speeds to determine if you ran better, or not. Starting mph varies, sometimes the actual point where you take off varies, and some cars are already accelerating to the point where the hopeful take-off speed is set. All you can really hope for is an even start, and then whoever crosses the finish line first.
I've always said the cars were basically dead even through 3rd gear, but once at the top of 3rd and higher, the Viper pulls away very hard. That was even how my runs against them went. It is also evidenced on their similar 1/8-mile trap speeds, but the Viper is 2-3 mph faster by the end of the 1/4. I do think an A8 Z06 will hang better, until it goes into 5th+, where it seems to have a large gearing drop-off.
Keep in mind not only the tech issues they were having but I was 6 and so was someone else who was supposed to be 9. Or the other way around they didn't tell us when they gave out numbers. There are a few people mentioning the posted data is off. I know 155 was my best but I also know my start speed was above 60 so I didn't really count it
#33
1. $hit will break
2. Always someone faster
All in all the Z is a fast car and did great. Keep in mind its designed for downforce and at speeds it does that great that's what it has such good lap times. But as we all know downforce = drag. The viper does not have that level of downforce and its NA so heatsoak and timing pull isn't a concern.
Im not trying to turn this into a dick swinging contest, if I was I would be the one saying it wasn't fair cuz it was tuned and I still had my aero on blah blah blah. I was outrun by a worthy competitor.
At least that civic didn't get us or we would both have to sell our cars.
#34
Not much, I was say my nose was on his rear bumper but that gap would only getting bigger as the speed climbed. I could tell he was just walking away
#38
Tony
#39
Looks like that would be more even. Then add an MGW shifter too!
#40
Not really because tuning is mapping the entire rev range which will better results than just slapping on an intake. A proper tune makes all the difference.
