--RELEASE-- LG Motorsports Forged ZR7 Wheels
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
-Release-
LG Motorsports is proud to introduce their new ZR7 wheel for Corvette.
These one piece, forged wheels not only will add style to your Corvette but are also stronger and lighter than OEM. Compared to stock these wheels are 3.9 lbs EACH lighter in the front and 5.8 lbs EACH lighter at the rear than the stock C7Z06 wheels. Total weight savings of 19.4 lbs of rotational unsprung weight!!
For wide body cars we are building 19x10 front and 20x12 rear. For standard body cars 19x9 front and 20x12 rears. Ask about custom sizes for other fitments.
MSRP $5695
Wheels are built to order, and allow 3-4 weeks for delivery on your set.
We have a wide selection of no cost optional colors.
- 23.6 lb front wheel
- 26.2 lb rear wheel
- 18+ lb weight reduction over stock OEM C7Z wheels
- One piece Forged construction
- Billet center cap with LG logo
- Your choice of colors
- 19x10 front 20x12 rear (wide body) OR 19x9 front 20x10 (std body)
- Fits C7Z07, C7Z06, C6ZR1, C6Z06, C7, GS, C6, and C5 (ask for other fitments)
- Accepts OEM TPMS
- Accepts OEM Lug nuts
- Wide selection of colors
ACT NOW! For the next two weeks only we offering an intro special price of only $5295!
How does this compare to the weights of the C6 ZR1 20 spoke or Cup wheels?
What colors do these wheels come in?
Former Vendor
You can get them in almost any powder coated color at no cost. Multi layer finishes (like a transparent smoke or brushed/clear) are extra.
couple of questions for ya:
1. are the offsets the same as C7Z06?
2. Is silver color an option? what kind of silver do you have? Any pictures?
3. can I get them with TPMS and tires already installed? Michelin Pilot Super Sport ZPs in stock sizes? Or would I have to get the TPMS and tires on my own?
Andrew
Andrew
Former Vendor
Andrew
Andrew
1. They are slightly more aggressive but we can do stock offset
2. Silver is....but right now you are looking at the only set that has been built. We can do matte, gloss, metallic or normal...lots of silver choices out there. If you have a specfic one let me know we probably can match it.
3. You can get your own, or we can do them as a ready to roll set. FYI Super Sports are on back order right now until the middle of June as an estimate, which would put them ready about the time the wheels would be.
Former Vendor
Our first customer, Ryan just got his wheels in last week and sent us a quick pic of them on his new Z06!
Looks awesome Ryan!!
i dont know much about offsets. does "aggressive" mean a large positive or negative offset?
does aggressive mean they have a large offset so they look cooler or so they perform better on a track?
when something is said to be aggressive it is usually to get a strong benefit in something, but something else is usually compromised. What is the benefit and what is the compromise of this aggressive offset?
thanks - mark
Former Vendor
thanks - mark
thanks - mark
"aggressive" means the offset is going to push the wheel further to the outside making it more flush with the fender of the car. You can change how a car is going to perform on track by doing this. Taken to the extreme you can widen the front and narrow the rear and the car would rotate better, or vice versa you can make them more stable at speed.
If you remember the old Pontiac commercials for the GTO "Wide Track", that made the car wider so it would handle better by giving the car a more stable, and "wider" platform.
In some cases, if you are trying to fit a very wide wheel and tire setup, you might not be able to go as "aggressive" as you need to make sure the tire is not going to hit any of the body work.
I hope I explained it, since these are custom built to order wheels we have a number of options when we go to produce them.
Former Vendor
Top quality finish, made right here in the USA with a number of colors and a light weight wheel is the end result.
Take 20lbs of rotational, unsprung weight off of your Corvette now with the LG Motorsports ZR7 Forged wheel!
