Apsis: Z06 Stage 2 & 3 Carbon Splitter/Side Skirt in stock....wants to order???
Premium Supporting Vendor
Hi All,
Just got a shipment in and still have couple kits available for Stage 2 & Stage Aero Kit. Anybody wants to order? No waiting.
These are 100% replica of factory parts and look even nicer than factory visible carbon parts. The factory carbon parts are made by prepreg carbon. This process requires high heat and high pressure so it lost the "depth" somehow. Our process is INFUSION which requires NO HEAT NO PRESSURE at all so it will show carbon's natural beauty. Some customers have received our parts and they are very impressive.
For Splitter, you will remove all the existing screws and reuse the screw holes and hardware. For Side Skirt, we provide self tapping screws for installation.
Other than visible Carbon, we also have it in Carbon Flash available.
Stage 2 Carbon Splitter including the winglets $1288
Stage 3 Carbon Splitter including the winglets $1888
Carbon Side Skirt $1288
Stage 2 Carbon Flash Splitter including the two side pcs $1098
Stage 3 Carbon Flash Splitter including the winglets $1698
Carbon Flash Side Skirt $1198
If you have stage 2 or stage 3 center pc only due to GM's constraint, then you can purchase the Winglets only.
Stage 2 Carbon Windglets Only $398/set
Stage 3 Carbon Windglets Only $898/set
Stage 2 Carbon Flash Windglets Only $328/set
Stage 3 Carbon Flash Windglets Only $798/set
Due to limited inventory available now, first come first serve. If we run out inventory then please allow us 2 more weeks lead time waiting for the next shipment to arrive.
There are many pictures on our web. We just check pick some pictures here for your reference.
Stage 2 Splitter:
Stage 3 Splitter:
Side Skirt:
Stage 2 Splitter:
Stage 3 Splitter:
Side Skirt:
Red Corvette looks great!, it's a photo of Caravaggio's stage two splitter and rockers. If anyone wants to see the original post go to post #78
under "Caravaggio Z06 front splitter" .
or this thread:
https://www.corvetteforum.com/forums...-c7-z06-s.html
or this thread:
When any product is new, there are always some unexpected glitches. Even C7 or C6 Corvette, the first year always have some issues. Once the bugs are taken cared then no more issue. This is the nature of business.
