New ride heading home, and....
a puff of white smoke emerged from the hood vent....when i popped the hood it looked like a small amt of coolant (white residue under the hood, and on a component or 2....small amt..but it was there) had stained and left evidence of itself......anyone care to share some wisdom ?
literally 3 miles from the dealer to my house.....stopped at 1 red light.....3min light......and the puff emerged
Not sure what it is but I remember reading a post earlier this week about someone having a similar problem. Search the forum and you should be able to find it. He may have found the cause of his problem by now. It seems like his operating temps were odd as well.
Did it have the sickeningly sweet smell of coolant? The hood and vent design of the C7 series tend to hold and direct some water to the engine causing it to turn to steam. If your dealer washed the car, which is likely, that is probably what you experienced.
There was a video earlier of one that was putting out a frightening amount of steam from the hood vent after it had been washed a short time earlier.
your wash theory makes me feel better (i'm betting/hoping you are correct)
I left my house with a lot of dew on my car. A few miles later I saw steam coming from the front when I stopped facing downhill. What happened was caused by the water rolling forward and down the hood vent to the radiator. The car must run a while for the radiator to warm enough to make the steam, so it happens only when condition are right.
You mention residue, could that be from residual cleaning product below the vent?
You let the dealership wash your new beast?
