Cup 2 tire freeway tracking
my cup2 tires on my new Z06 seem to follow or track freeway groves
and other surface flaws.
do other owners of these tires experience the same things?
i would also like to know if the standard super sports exhibit the same tendencies. i realize all wide tires will follow irregularities in roads, but these seem worse than the stock tires on my C6Z51.
Normal on these size tires!
Along with your Owners Manual came a pamphlet titled "Getting to Know Your 2015 Corvette". On Page 14 there is a warning about groove tracking on some roads (although I did not find the same warning in the Owners Manual and the warning did not specify which type of tire) so GM is obviously aware of the problem with these tires in general. I have not driven on the Cup 2 tires so I have no way to compare them to my standard Super Sport tires. However, I did encounter what I thought was a mild tracking problem on an interstate in some locations, so I changed lanes to another lane that did not have the groove pattern and the problem stopped.
YES! And it was very interesting in heavy rain with some puddles, while transitioning from one freeway to another. Happy about all of those Spring Mtn classes that taught me what to do in unexpected circumstances. A short 2 minute period but one to remember. Thank you Victor, Dave & Dave.
Janet
Janet
Received 8,958 Likes
Adding just a shade of toe in can drastically reduce the tramlining.
Bill
Bill
so now i have a name to refer to this by, "tramlining". i think i will try adding a little toe in as bill dearborne suggested.
i really just wanted to know if the standard pss tires did this to the same degree and from a couple of responses, it seems they do.
my c6 z51 with factory Goodyears did this to some extent, not nearly as much as the cup2's on the new z. they are of course, smaller.
The biggest variable is the alignment, and all Corvettes are just roughly aligned at the factory (between the green right and left marks and it is good to go). As "Fasttoys1" mentioned a couple of months ago, getting his car aligned to factory specs made it "handle" such much better. Had mine, precisely to spec, four-wheel aligned too, and it tracks very nicely, even thought all our Z's have humongous front tires.
Getting a precise alignment is critical for good performance especially on track. Track specs are terrific. The car has tremendous turn in, stability and grip. My car has Z07 with Cups. First day out on track before alignment definitely sketchy.
