Tall people in a Z06?
They ruined it.
I fit fine in the C5 and C6.....but C7 is short and tight.
Can't drive fast if you're not comfortable.
Its a pretty car though.
Maybe just as well....cuz in my search I found out that there is C5 leg room in a GTR! And its quicker! more traction and all.
It just looks like a dork-mobile.....but you don't drive a car from the outside.
I wish I could put the C7Z body on the GTR, then I would have the best of both worlds.
I'm 6' with a 36" inseam but only 145lbs, I'm reaching for the clutch at full press and still have room to put the seat back. Haven't tried stuffing my 6'4" hubby in the car yet though. Helmet not a problem, I bought the convertible, so I have plenty of leg room. My only seat complaint (and I have the GT seat) is that the bottom side bolsters are poking into my thighs just below the hip, but I think those will soften up with use.
My concern/issue (as I should have detailed in the first post) was/is headroom. I had the seat all the way back and pushed the clutch to the floor, and I have enough room with a 34" inseam. And no, my head wasn't hitting the glass top by any means, but boy was I close to the roof, thus my helmet concern...
The interior of the Z06 is the same as the Stingray -- I was told that the legroom, headroom, etc. were all the same.
Having crawled around inside the C7 cockpit....I'm pretty sure any of the length and height issues could be resolved with a fixed back race seat like a Sparco or Corbeau......
Part of the issue is the embedded airbags in the seats make them thicker. (and maybe higher?).
A fixed back racing seat is a pain to get in and out of for a daily driver, but another solution would be to install a seat from a C5 which doesn't have the embedded airbags and has a lower seat height. The mounting posts might even be in the same location.....if it was the same electrical connector that would be a miracle.
But then the question is would the car let you drive it around with an airbag error code.
LG would know.....those guys are very dimensional oriented.
Im 6'4 275 lbs...I fit fine. Its not a caddy or anything, its a cockpit as it should be.
Fit in my C5 was great. Fit in my C6 is a lot tighter but still works. Fit in the C7's I have sat in are extremely tight for me. Almost a no go. I am 6'6. What the heck are they thinking by shrinking these things each generation? They keep posting numbers that look nearly the same between generations, but the fit is nowhere the same. Oh, and I'm not heavy and I know how to adjust these seats for max room. C7 is tight anyway you slice it.
6'4", 270, 34" inseam. No issues driving my student's car at VIR this summer. Car had comp seats and the solid roof in place. Have to get the seat right. Have to incline the seat back first so you can get the base all the way down and back. If the seat back hits the rear panel the whole seat stops moving. I think many don't actually get the seat down. Found I fit better by sliding the seat 1" closer so I can recline the seat a little. Didn't try disconnecting the seat sensor.
#33
I went to a friend's house this weekend to finally lay my eyes on the Z06 The car sounds incredible and I really liked the interior. My question is this-are tall folks buying these things? I'm 6'1"1/2, 200 lbs.-(not tall at all)- I had the seat all the way back. The seat situation is just big enough for me. The friend, who was doing some paint correction on the car, is 6'4". He says he couldn't own one-too small inside. I have been planning to buy one in late 2015 or early 2016, and still plan to. That said, I don't think I could fit with a helmet on... Am I missing something, or am I right? Thanks!
