C7 Z06 1/4 mile 11.1 @ 128 VIDEO
I saw this video this morning in my Youtube news feed. Sounds and looks stock to me, maybe someone who knows a bit more could chime in.
Looks to be a good run even while spinning off the line.
EDIT: If this is a duplicate thread moderators can lock if needed.
Turn 12!
Z07 with FULL areo too. Just imagine with the areo pieces off. 10 sec car easy.
It will be quicker with some better traction, but warmer temps can take away some of the good air that you need to make power. The head/cross wind will affect the trap speed quite a bit. Without the wind it's likely it would have hit 130.
His first time in the new Z down the 1320. Said traction was a big issue.
Good stuff!
This car is completely stock, with drag radials, you saw in the video how bad the car spun on the drag radials, what would have been the point running on the factory tires? Cause you know the factory tires would have roasted up real easy, so it would have been pointless,no info would have been gained from that.
Nice work! Thanks for this Tony!
