Sponsored by: GEM Motorsports
The GPS in your PDR does not measure speed
Old 12-26-2014, 06:40 AM
Shurshot
Shurshot's Avatar
Default The GPS in your PDR does not measure speed
GPS works through determining the time taken between two GPS reference points and then does the math to come up with a speed. The shorter the distance being measured while radical changes in speed are taking place, the accuracy of the unit heads south.
Civilian GPS is something like within 10 feet plus or minus with good reception
It is not a like laser or radar that works by recording time from a sender to an object back to the receiver
Old 12-26-2014, 08:39 AM
camarodoctor
I ♥ My Corvette
Support Corvetteforum!
camarodoctor's Avatar
So you're saying that it's possible that a PDR reading at 60 mph may actually be 65 mph?
Old 12-26-2014, 09:02 AM
Jet Stream Blue Z06
Jet Stream Blue Z06's Avatar
Doesn't the PDR get the speed from the car just like it knows how much brake or gas you are applying, or what gear you are in?
Old 12-26-2014, 09:07 AM
DRLC5
DRLC5's Avatar
So is the PDR speed separate from the actual speedometer in the car? I do not own one just yet so I am curious.
Old 12-26-2014, 11:34 AM
CaryBob
CaryBob's Avatar
I don't think the OP is questioning 0-60 times, but rather the time to cover a distance. GPS has nothing to do with the speedometer.
Does the car use tire revolutions or GPS to measure distance covered?
Old 12-26-2014, 11:56 AM
peterjank
peterjank's Avatar
Possible, but doubtful. In my race cars, I have used Aim data acquisition systems that measure speed via both GPS and actual wheel speed since 2008. When cars are going straight and wheels have good traction, GPS speed and wheel speed rarely differ by more than 1 mph.
When you have wheel spin, GPS obviously provides more accurate speed numbers than wheel driven measurements.
GPS speed may be less accurate than wheel speed when the GPS antenna is struggling to get a fix on satellite locations due to heavy cloud cover, rain, surrounding buildings, etc.. The Aim GPS produces its best results when its antenna is able to lock on 9 or more satellites. It normally won't work if it can only spot 5 or fewer satellites. As the number of satellites falls from 7 toward 5 you may start to see some discontinuities in GPS speed measurement.
I don't have any direct experience with Corvette PDR yet, but my guess is that its GPS speed measurements exhibit characteristics similar to what I have described for the Aim systems that I use.
Old 12-26-2014, 12:04 PM
dar02081961
dar02081961's Avatar
I think if you did more research you would find these statements arent accurate.
Old 12-26-2014, 12:06 PM
Speednet
Speednet's Avatar
From an engineering talk given earlier this year, I seem to recall the person saying that the GPS in the PDR is separate from the GPS in the navigation system, and that the PDR's GPS is more accurate and takes more readings per second. It's accurate enough to know what part of the curve you took. Which is pretty accurate.
So I'd say the OP is not correct when he says (with no backup proof) that the GPS is not accurate over short distances for measuring speed. I think the OP does not seem to have experience with high-accuracy GPS systems. These systems can be very accurate for recording speed, distance, and location.
Old 12-26-2014, 02:09 PM
begone
begone's Avatar
If I can download a $20 app on my phone called "Harrys Lap Timer" , I'm sure GM can figure out a GPS based accurate system for all of these times and speed figures...
Old 12-26-2014, 02:18 PM
PushNut
PushNut's Avatar
Default What
does the 2 things have to do with each other?
Your phone skills do not in any way relate to GM's ability to allow civilian access to high accuracy GPS satellites...
Old 12-26-2014, 02:41 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Harry's Lap Timer is an APP that uses the IPhone GPS system to collect speed and other data while a car is on track. I used it for two years and found it to be accurate. The poster above is saying that if an independent person can write a program to access and use successfully GPS data, it should be a piece of cake for "Big GM" to do the same.
Old 12-26-2014, 02:55 PM
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Steve Snake Driver's Avatar
Cosworth worked with GM in developing the PDR. They do the data gathering/telemetry for the C7R. I suspect they know a thing or two about how this stuff works.
Old 12-26-2014, 04:52 PM
Shurshot
Shurshot's Avatar
Maybe so?
I was acting on the info posted on another thread stating the PDR ran off of GPS. If it is getting info from the speedometer it may well be getting info from the odometer as well. If that is the case the point I am making about the limitations of accuracy associated with GPS is moot
However, if it does gain speed, location and distance traveled information from GPS sensors as most plotters do, the shorter the distance with the greatest variance in speed will be more prone to error than a longer distance with more constant speed will be.
Or, in other words, concerning percentage rates of error, a PDR running off of GPS inputs will be much more accurate with the information posted on a one mile run then it will be for measuring 60 foot hole shot times, or a 1/4 mile run versus a 2 mile run
Old 12-26-2014, 04:59 PM
Shurshot
Shurshot's Avatar
Through my experiences navigating at high speed in low light conditions where time and distance accuracy could mean the difference between living and dying, I can say my statements are very accurate.
Fair enough?
Old 12-26-2014, 05:06 PM
begone
begone's Avatar
You learn something everyday. No but seriously, check out that app. It's highly respected and accurate. But you'll need what those pesky kids call a smart phone.
Old 12-26-2014, 05:25 PM
Blvdbrawler
Blvdbrawler's Avatar
The MPH on the PDR is very accurate. Honestly, why have it and give it to customers if its going to give you the wrong information?? I think its very close or right on point as to how the car is actually performing. (Unless the OP or anybody else can prove otherwise?)
Old 12-26-2014, 05:36 PM
FLATOUTVIPER
FLATOUTVIPER's Avatar
Without running it at the track and comparing it to the time slips you guys will never know how it compares to the actual track. I don't really see why this is hard to understand.
To The GPS in your PDR does not measure speed
Old 12-26-2014, 05:38 PM
c6z07
c6z07's Avatar
THANK you someone with intelligence lol. How can you claim it's accurate but not have a slip to prove it
Old 12-26-2014, 06:12 PM
Shurshot
Shurshot's Avatar
This X2 ^^^^
Old 12-26-2014, 06:41 PM
Steve Snake Driver
Fair enough?
I believe a big difference is that you didn't have a wheel in contact with the ground adding data to the overall equation (at least if I catch your drift). The PDR has 30 or so acquisition channels. To assume it only relies on GPS is probably wrong.
Quick Reply: The GPS in your PDR does not measure speed
