Vette magazine test of Z06
#61
The C7 Z06 auto has a 2.41 rear gear but a stump pulling 4.56 first gear.
#62
10.5 bone stock? Lol.........ol.
#63
10.5@130 is the time most people expected and would have been ecstatic over...with all the issues/extra downforce we know now I don't see that happening...under 11 yes mid 10's NO..
#64
I think the problem is the drivers, the cars are very capable but just because a c7z owner go's to the track and dont get good runs in its the cars fault? what about driver error, track condition, tire pressure and weather? just cause some one has the means to pick up one of these cars it does not mean he or she is a good driver.
I have a friend the has a c7 ran back to back 11.7's all stock on stock tires 460hp, now the c7z with 650hp is only running 11.5x? 190hp more? just cause the car is able to do it does not mean every buddy can do it.
I have a friend with a gt500 stang with a tune and bolt ons he should be running 11's his best run is only a 12.2x but he's a not the best driver its as simple as that.
#65
Looking forward to seeing some drivers take these cars out to the track!
#66
Former Vendor
Can and A8 Z run 10.5's? Hmmm, possibly, but I think it will need at least some DR's and great track prep. Adding a tune and a CAI kit will certainly help, and may reach that mid 10 mark on stock tires.
Back in 2006, I ran 11.4's @ 127 with my Z06 - BONE freaking STOCK with GY run craps!!!
A month or so later we added: a tune, ARH w/cats, my vette-air scoop with stock blue paper filter cut in half and ran: 10.9's @130 - yep...again with GY run craps.
As far as the new Z, I'll be able to better judge its potential once I see some real bone stock runs with stock tires then predict. Meaning, let's see what real people with some racing background/skills can pull off from it.
Right now things are looking a little fuzzy, but time will tell.
Thanks,
Carlos
#67
Thanks,
Carlos
Thanks,
Carlos
#70
Former Vendor
FWIW, my runs back in the day were not hero runs, I backed them up by running back to back to back...just how I do things when tuning/testing on the dyno to verify "real" gains/improments.
Thanks,
Carlos
#71
Former Vendor
If you recall, the stock LS7 air filter was a huge hunk element. We decided to cut it in half or slightly less than half - from left to right and glued the layers using floor carpet glue. The filter went from roughly like 8" (front face to back face) thick, down to rougly 4" or slightly less.
Cutting it down in size increased air flow. Oh yeah, we also removed the carbon mat that was glued inside the bottom of the stock air bridge. We tuned the vehicle to take advantage of this new found breathing capabilities
It was our little secret back then; folks were like: how is this car running consistently 10's on GY run craps. It also helped that many of us have been drag racing for years - driving/using the power at the track or streets is not a problem for us
Thanks,
Carlos
Thanks,
Carlos
#72
Assuming stock rubber....10.5 wont happen........Traction limitations are going to be a factor....
#73
Thanks,
Carlos
Thanks,
Carlos
First of all, On the C6 Z06, it's not 8" from the front face to the rear of the filter, but is 5 inches. no way did any C6 Z06 come with a paper filter that had an 8" depth.
Second, if one were to slice the filter in half, then you will cut the filtering area in half, meaning you would get less air flow as you would be forcing the air to pass though half the square inches of filtering media. Of course, when you sliced the filter in half, then you would have to seal every one of the tubes that were sealed originally( hundreds of them) on the exit side of the filter, in order to have any filtering of the air. If you didn't seal them up, then you would have zero filtering of the air.
On the front of the PowerCore filter, every other "tube" is open and the adjacent "tube" is closed. On the backside(exit) of the filter, the tubes that are open on the front(entrance) are closed and every tube that is closed at the front is open at the rear.
The incoming air enters the open tube at the front of the filter and passes through the tube's paper wall into the adjacent tube and exits out the open tube at the rear of the filter.
Instead of the (actual) 5" length of the tubes, cutting then in half, would reduce them to 2 1/2" in length, thus cutting the number of ultra tiny openings in the wall of the tube to half of what they were when the length of the tube was cut in half.
What you did was the equivalent of the racer 40 years ago that removed a 14" diameter x 3" tall paper filter on a 1966 SS396 and replaced it with a 14" diameter X 1 1/2" paper filter. That's not what we did back then. We stacked two filters to get a total of 6" height to help get additional air to the carburetor, by providing twice the filtering area.
#75
#76
I go to the track a lot guys less say with something that's suppose to run 12.50's can only get a 13.20 ET they always say the same thing "SOMETHINGS WRONG WITH MY CAR" yup the driver! my cousin has a ctsV when he drives it car runs 12.50's, we pulled him out of the car so some one else could drive it and they got back to back 12.1's on the 3rd and 4th passes never drove the car before except 4 times down the track and its an auto
#77
He explained further that this is what they PUBLISH... so watch the video and then ask yourself if you can believe any times they publish as times THEY were able to replicate.. crazy after all these DECADES you hear it from (one of the ) horses mouth what many of us always thought was an impossibility.. manufactured times?
#78
Received 1,580 Likes
Thanks for this info. I would say definately capable of a 10.7 in the 1/4 due to the rear and HP then. Auto should be able to pull a 1.6/1.5 60' with a 4.56 first gear. Tracks in NJ will get the job done!
#79
When I read some of the replies in this thread I have to chuckle. I can say this that after running both my previous Corvettes in the Corvette Challenge up at Englishtown for 8 years before moving down here to SW Florida in 2011 there's a bigass difference between so called "published times" and reality. The first thing you have to do is forget totally any published times and concentrate on "seat time" ! Learn to drive your car first. The more experience the better chance you'll get at even being close to what the car's supposed to do. And run at a well prepped track and listen to the guys that run all the time. I can tell you this that with some of the best racers up there in the country I can count on one hand the times I saw guys consistantly run their C6 Z under the so called "published times". The same will be true with the C7 Z's too. You can count on that.
#80
