Sponsored by: GEM Motorsports
Leg room in Z06
Old 02-26-2015, 05:35 AM
  #41
Blvdbrawler
Blvdbrawler's Avatar
Originally Posted by JMB
I unplugged the harness in the pic and this mod is a bust for the Z06...maybe it works for the C7 Stingray but I GUARANTEE zero results of the seat moving back any further on the Z06 (I have the base seats). I measured a before and after and the results were identical
Are you sure you unplugged the right thing? (JK)
Thanks man! Will just have to do the adjustment trick...Should be fine!
Old 02-28-2015, 12:24 PM
  #42
C2Jeff
C2Jeff's Avatar
Originally Posted by RACE U
If you track a z06 coupe, can you do so without the roof panel in?
I don't see why not, weather permitting.
Old 03-14-2015, 08:55 PM
  #43
jrz1
jrz1's Avatar
I just did this. Why the heck did I wait so long? I'm not sure exactly how much extra room I gained but it is noticeable and makes a huge difference for me given I'm 6'4" tall. Have to check and see if the passenger seat has the same thing as that's even worse (not that I ride as a passenger too much).
Old 03-15-2015, 09:32 AM
  #44
IslandZ06
IslandZ06's Avatar
I bought my C7 Z06 "new used" with a few hundred miles. The owner traded it on a C6 Z06 because he was a big guy and fit in the C6 better. Little strange but...
Old 03-15-2015, 10:46 AM
  #45
JMB
JMB's Avatar
You might want to plug it back in and re-measure....I did and it makes zero difference (I used a tape measure and measured the distance from the brake pedal face to the front seat seam...you might want to do this too)!
Old 03-15-2015, 10:21 PM
  #46
jrz1
jrz1's Avatar
Don't rain on my parade. It seems a lot better so I'm sticking with it.
Old 03-15-2015, 11:07 PM
  #47
s_c5519
s_c5519's Avatar
In that case the mod might have made the seat go lower, but either way, there is a difference in leg room for sure and my arm is also further away from the wheel which was the first thing I noticed after the mod. I have a way that I rest my arm against the door panel and my elbow isn't as bent now...
Old 03-16-2015, 07:29 PM
  #48
jrz1
jrz1's Avatar
Agree. Haven't had a chance to measure but before my knees were literally almost touching dash under steering wheel and now I have at least an inch or two of cushion. It is much better.
Old 03-19-2015, 10:07 AM
  #49
Flynbyu23
Flynbyu23's Avatar
I'm 6'2'', and I have noticed the cabin of my Z06 is smaller than my C6. I still love the car though. It's light years ahead of the C6.
Old 03-19-2015, 11:44 AM
  #50
Guard Dad
Guard Dad's Avatar
I don’t know about the seats but that is a FINE looking ride. Love the chrome wheels.
Old 04-04-2015, 05:59 PM
  #51
s_c5519
s_c5519's Avatar
Just an update. I did this mod to my new '15 Z06 (the pic I posted earlier was from my '14 Stingray), and it also made a noticeable difference. I have the competition seats...
A huge thanks to Carnut52 in this thread for the tip. Those extra couple of inches really made the leg room and longer arm reach perfect for me.
Old 04-05-2015, 02:07 AM
  #52
Richard Joash Tan
Richard Joash Tan's Avatar
Don't order the sport seat! Suspect you will not find seat especially comfortable unfortunately. It could be a reason I don't keep the Z for long term.
But this is why I will buy the Fully-Loaded Z06 Coupe since I am 6'1".
Old 04-05-2015, 04:59 PM
  #53
quadeddie
quadeddie's Avatar
Originally Posted by mte.smiles
GM are you listening? You are losing sales to the tall folks like me. I'm 6'7" and 320 pounds and my 07 vert is comfortable even with the top up. I could barely fit into the 2015 C7 and therefore won't be getting one unless you (GM) can restore the room of the C6.
It's easier to bring Moses to the mountain than bring the mountain to Moses. Try losing 90lbs before complaining.
Also, for those who are doing this mod, remember to undo it when taking the car in or you could have a shop monkey blow your seat motor.
Old 05-22-2018, 06:57 PM
  #54
1967gep
2nd Gear
1967gep's Avatar
Default which seat
Originally Posted by carnut52
Unplug the seat limiter. Pull up the carpet behind the drivers seat. There is a plastic stripe that has two white wires at the top. Follow those toward the passenger side and there is a small black harness. Unplug that and you will have 2" of leg room. Did mine yesterday
So is the plug behind the drivers seat or the passenger seat, I have a 2015
Old 05-22-2018, 10:27 PM
  #55
dollarbill
Support Corvetteforum!
dollarbill's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11
Originally Posted by SBC_and_a_stick
I think the headroom is the worst. I banged my helmet into the roof on both sides of the car. I'm not too tall and I'm mostly legs. I can see tall people having a real hard time fitting in with a race helmet.
Get the transparent roof and you gain a couple of inches of headroom.
Old 05-23-2018, 01:14 PM
  #56
Ask_Griff
Ask_Griff's Avatar
Default I had Issues
I'm 6'4" 235lbs and I could not fit into the Z06. I suspect that it may have been due to the sportier seats. I ended getting the Stingray because I could actually fit into it better. I recorded a video of how I gain a bit more legroom. Now that I figured this out, I'm wishing I had gotten the Z06.
Old 05-23-2018, 06:16 PM
  #57
1967gep
2nd Gear
1967gep's Avatar
Default need more leg room
Behind the drivers seat, mine is a convertible, so do I pull the carpet up in the trunk, or from the door opening????
To Leg room in Z06
Old 05-23-2018, 06:45 PM
  #58
Thomasmoto
Thomasmoto's Avatar
Received 1,507 Likes on 1,028 Posts
Default seats
https://www.youtube.com/watch?v=8DDwwtWdnsY
Those seats are the GT seats and they are available in the Z06. When I bought a 2015 M7 Z06 it had the Comp Seats and I didn't care for them. Sold the car and ordered a 2016 A8 with the GT seats, all is well. I'm 6'2" and approx. 275. One addition is I CAN'T fit in the pass side. I have to drive or I can't ride in it. There is an appreciable difference in the leg room of both sides.
I had the same experience with the Z07 package in my 2015, it was just too rough. The Z07 really makes it more for the track than daily driving.
JMHO
BTW I track my car some and getting out with my helmet on takes a little for thought. It's a bit tight, but doable. We have to pass a 12 sec fire exit drill for the Optima Series. In full fire gear.
Old 05-23-2018, 11:17 PM
  #59
Ask_Griff
Ask_Griff's Avatar
JMHO
Yikes!!! The video I attached to my original post is me and my 6'3" son giving an overview on how guys of our height with a 36" plus inseam fit into the C7. Just as you mentioned, the passenger side is far worse than the driver side. My video shows how I figured out how to position my left leg when driving.
Old 05-23-2018, 11:22 PM
  #60
Ask_Griff
Ask_Griff's Avatar
Check out my video below. It may prevent you from having to disconnect the seat limiter. I was also thinking of doing that, but I heard that you don't really gain much. My video shows how to potentially get more room for your left leg. Not much I can tell you about the right leg.
Quick Reply: Leg room in Z06
