Jalopnik says return on Z07 with 8 Speed Auto
Yup, same info circulating some members posted from Hot Rod Magazine. I have hope the numbers will be more since it has estimated and since the stingray was also estimated, it came out with a little more!
I'm 6'6" tall love corvettes even tough it's a struggle to drive my ZR-1 with a clutch having owned several Z06's also I cursed the fact that an auto wasn't available. Now that I hear the new Z07 is being offered with an auto I'm disappointed that the C7 is rumored to have less interior room for taller drivers. If this is true GM has taken a segment of the market & made it impossible to own one. Since I haven't had the opportunity to try & fit into a C7 yet I will have to reserve any judgement that I have owned my 20th & last Corvette till then.
Received 19,293 Likes
'20-'21-'22-'23-'24
GT3 has a very stiff clutch pedal (and very "high up" from the floor , if that is the right way to describe it--meaning your left hip is constantly bent at a 90 degree angle) ....my ZR1 has the nicest clutch pedal of any car I have ever driven...have you tried the new M7 C7 to see if you like the manual better than your GT3?
Love the clutch on my ZR1, but I am only 6'0"
The Consigliere
Received 5,444 Likes
Don't need to be a good heel/toe shifter with the C7. It offers rev match capability on the manual. And you can turn it on or off at will.
reply
My torso isn't the problem I have long legs. For example I couldn't even dream of fitting in a Viper or some of the mustangs. Don't laugh but I have to take my shoes off to drive my ZR-1 any distance comfortably. My 997 Porsche isn't a problem. So GM has seen the last of my money if it turns out I can't comfortably fit in a C7. I'm certainty not interested in any of the other junk they build.
