Shaking and rough idling and struggles to accelerate
What’s up guys , I have a 2017 stingray and recently I’ve done my longtubes. When I did them there was a o2 sensor I had to replace simply because I couldn’t get the oem one out. The car has been running fine for 2 weeks then out of no where she started shaking sounding like it was trying to die. Then it’ll catch itself and start back running normal. A day later it started shaking randomly then misfire in multiple cylinders. I checked all of my plugs (they were brand new) all of them were good and pinned not even a speck of dirt on em. I went to pull up a check engine light and noticed that my o2 voltage in bank 1 sensor 2 was spiking up and down the whole time while the car was shaking and misfiring. What you guys think??
Received 19,440 Likes
'20-'21-'22-'23-'24
Moved to C7 Tech for assistance.
6.2zay (03-25-2024)
ShawnZR-1 (03-18-2024)
Shaking and misfiring after wide open throttle
'20-'21-'22-'23-'24
I think this would be better placed in the C7 Tech section.
Moderator, Tech Contributor
Received 2,138 Likes
All I see is the upstream O2 sensors which are supposed to “switch” between 200-800 millivolts…the downstream sensors “ sensor 2” are fairly constant around 700 millivolts…if downstream sensor oscillates like the upstream the catalytic converter has lost its ability to store oxygen…this may also be an exhaust leak anywhere between the upstream and downstream O2’s !!…do you have a P0300 stored ??
Looks like you have an intermittent circuit on Bank 1 Sensor 1 in front of the driver's side cat. Usually means the wire harness got torched by touching the header or one of the connectors isn't fully seated. Surprised there's not a code and check engine light unless they're turned off in the tune.
Based on that sensor trace I would then lean towards a bad sensor, even if new. Also make sure you have them routed correctly and don't have the aft o2 sensors being used as the primary.
Red86Cfour (03-28-2024)
okay so update. I just swapped bank 1 sensor and cleared codes before starting the car. After I started the car went to do a code scan just to make sure and code “B1325” had came up saying “control module power circuits voltage below threshold” also another code “U0078” stating “control module communication low speed can bus off” and 3 more “B125C” “U0078” “U2098”
