Diablo or Range.
Diablo or Range.
Thinking about getting a Diablo !3 Platinum. I mainly want to turn off the v4 mode., but read that i can do a little more "can" tuning with the Diablo. What over adjustments can I make with the tuner?
Turn off AFM/DOD, adjust idle, turn off CAGS, adjust throttle progression, adjust rev limiter, adjust speedometer, add canned tuned, get an email tune from someone like Diablo Lew, put it back stock if you want, view log on Diablo software on your computer, a few more things it can do.
Mike@DiabloSport (02-27-2024)
The following 2 users liked this post by Dcasole:
42059jim (02-26-2024),
Only way I see to really turn off the V4 mode is the Diablo. The Range is only useful if you don't want the V4 mode to engage. AFAIK, the Range keeps the car unable to enter V4 mode by not allowing the emissions testing to proceed. Do I care a whit about emissions? Not in the least. That said, I really don't want a "fooler" on my car. Every year, I have to get tested. With that dongle on, I will never be able to pass. This is why I think they tell you to remove it, drive for a while under different conditions to let the ECM do the readiness tests. After which, you pass emissions and you can reinsert it. This is ASSUMING you pass it. If not, you now have very little time, relatively speaking to get it fixed, do the readiness tests and pass. Way I see it, you might be running all year with faults that you don't know about. That and I have managed to kick the thing out while getting out of the car. Maybe it's a sign of what to do? I managed to sell it for a loss and get the Diablo.
Only way I see to really turn off the V4 mode is the Diablo. The Range is only useful if you don't want the V4 mode to engage. AFAIK, the Range keeps the car unable to enter V4 mode by not allowing the emissions testing ,Way I see it, you might be running all year with faults that you don't know about. .
The Range and the Diablo stop AFM exactly in the same way , they alter the parameters in the ECM that cause AFM to engage, by altering these parameters the ECM never sees the conditions that engage AFM . This action alone would set a CEL , Its how they handle the CEL is where they differ.
Diablo is actually altering the parameters in the tune when you upload the changes you requested to make on the device , because of this change there is no cel because the conditions to engage AFM are never met
Not that warranty matters much to most of the anymore but the Diablo also does not alter the CVN file in the ECM when you upload these or any other changes to the ECM which is how GM and others entities can detect if the car has been tuned.
The Range shuts off AFM by altering the parameters but it does so as a piggyback device using the communcations bus and since its not actually writing to the tune, the only way to clear the CEL is to run a "Clear CEL" command once it disengages AFM . This command is only used so the light does not come on as the ECM will still see that AFM is not engaged as the conditions to engage it have not been altered
If there was another fault with the car the light would still come on as long as the fault still exists so the Range will not hide a legitimate CEL
This is the same command that a handheld code reader or diagnostic scanner uses to clear CEL's and just like these devices , when u run this command it also resets the "Emissions Ready" status in the ECM . Now you have to do the drive cycle in order to be able to pass emissions
They both work great , its just up to the end user to decide which is best for them as , for various reasons not everybody is comfortable with "tuning" their car
Dave
Yes, I will be going with the Diablo. Is the any real difference between the 8245 and the 8246 other then price?. I see that the 8245 goes from 14 /16 models and the 8246 does the 17/19 models.Thanks for all the great info. I'm coming from a 2 wheel world and this is a new learning experience.I have a few videos of the car on my youtube 42059jim
CorvetteMike2024 (02-27-2024)
The 14 to 16 model does not have the unlocking ablity but i am almsot sure you can buy the credits to do it
I would check with Diablo Lew , just Google his name and it will take you to his page where he sells devices and also custom tunes . He answers emails pretty fast
Dave
CorvetteMike2024 (02-27-2024),
Supporting Vendor
if 17+, 8246 is the best place to start but either will work.
Dcasole (02-27-2024)
Dave
Dave
So are you saying that if I developed a problem that would cause me to fail emissions it would still show up? If so why do you have to run without the dongle for a bit before the emissions testing? Kind of confusing.
Thanks for the education.
Supporting Vendor
Very interesting. The reps wasn't 100% sure it would not leave a trace. If I understand you correctly, I can program it and remove it before I go to warranty work and it will be fine. Or did I misinterprete the statement?
__________________
Mike Litsch
DiabloSport/Range Brand Manager at Holley
Trinity T2 and inTune i3 now available for 99-19 Vettes!!
Subscribe to our YouTube Channel!
Mike Litsch
I know that about the range unit. Wasn't sure about the Diablo. Now I am. As a plus, I won't kick the Diablo out of the car and Ias a plus, I had the tip in for the throttle adjustments done.
My concern was what data was the range unit hiding from the ECM of the car
Spoiler
Dave
If you take it back to stock for warranty work, you will have to drive 60-100 miles to reset everything. If not they will get a few "Not Ready" sensors. I would then them them you had a dead battery and took it out for recharging. But it ready matters as far as what kind of warranty work.
