Why is Touring Mode much faster?
When I switch my 2017 Z06 to Tour driving mode, the car feels WAY faster than Sport or Track. Is it simply because Touring mode transfers the weight better therefore giving me better traction?
Any thoughts?
Any thoughts?
Changing between modes doesn't change the engine output so the car wouldn't be going any faster. If anything it'd feel slightly sluggish due to softer throttle response in touring. Weight transfer would allow the car to gain better traction at lower speeds so if you're spinning less than yes it would feel faster. Otherwise just some placebo you're experience unless you have timed proof.
Moderator
Maybe easier to steer but that's about it.
This is only applicable to drag racing. Cornering you will be faster in sport and race modes to limit the amount of body roll you get.
blackbird345 (10-03-2023)
If the tires are cold...the additional intrusion of T/C may give you better grip. Just a guess.
boost
Backpressure doesn't increase power.
I added headers and dropped my boost 2 pounds , but I can assure you I am making way more power than when I was at 7 to 8 pounds
Dave
Received 19,407 Likes
'20-'21-'22-'23-'24
