Range Device
There are many throttle amps out there. Most of them use marketing terms that are technically correct but try very hard to get you to believe you're unlocking power.
They just make the throttle pedal more sensitive.
The really trick ones will actually overshoot and back off the input to compensate for specific throttle bodies, but that's extraordinarily rare. Most just apply an amplification curve onto the input signal.
Very easy to do, push a few buttons and all done, no more AFM, car stays in V8 mode.
I'm sure it will work on your 14. You could call Diablo if you want to confirm.
Mike@DiabloSport (06-30-2023)
Yep, if you're cracking into the ECU you might as well just map the throttle there to a satisfactory level.
