Need feedback - engine surge at 1300-1600 rpm’s
Cruising
Just purchased a 2017 Z51. Love it. Noticed after driving it a bit that it seems to surge up and down a bit around 1300-1600 rpm’s when not under load. No issues when accelerating. Anyone else experience this or heard of this issue? It has about 18,500 miles on it. Thanks!
tjsdad007 (04-10-2023)
That could be a symptom of it needing the trans fluid triple flush. I don't recall the rpm, but it was at about 60 or so on the highway mine did that. Eventually I started to get the occasional shudder the A8's are known for. Do a search for triple flush and you'll see its fairly common on the pre 2018 cars. I think there is also an update to the transmission software that improves torque converter lock up they may do at the same time.
