Stabitrack check engine light and misfires
I have a 2019 Stingray with 7600 miles on it and took it out of storage today for a little ride. It began to misfire terribly and I wasn't sure if I would be able to get home. A light came on saying service stabitrack and the check engine light. From what I've read I don't see what the stable length would have to do with a misfiring engine. When I put the car away it had approximately 1/2 tank of gas and I added stabil fuel stabilizer. I was wondering if the gas was bad but I have done this for years with my cars that I put in storage and never had an issue. Has anyone else had this problem? Sadly the 3 year 36,000 Mi portion of the warranty ran out a month ago.
CorvetteMike2024 (02-26-2023)
Well I bought the car in January 20 so it's only 3 years old and I have kept a trickle charger on it anytime it is in storage. Although I would be tickled to death if that's what it took to correct the problem.
Flattman (03-01-2023)
TL, DR: It can be due to many things, which may have nothing to do with the rear axle.
Had a very similar problem after checking alternator, voltage regulator, battery all grounds and ECU it ended up being a bad connection at the fan!! Seems like all things electrical in these cars is tied together. I was just happy to have found the issue.
Moderator, Tech Contributor
Received 2,136 Likes
It is normal to get the stabilitrak light when the ECM sees a misfire...on some GM platforms you'll get the traction control light and other messages...I even see that on my Toyota 4 Runner if I shut off an injector or COP coil with my scan tool...if you don't have a scan tool you can take it to Autozone and they may be able to identify which cylinder or cylinders are misfiring with their scan tool...without some diagnostic equipment you'll only be chasing your tail and wasting a LOT of money...find yourself a DIAGNOSTIC shop and take the car there...they have the right tooling to quickly and accurately diagnose this.
95BLKVette (03-05-2023)
Dealerships are just PART CHANGERS !!…expect a big bill !!…like I said find a diagnostic shop…they diagnose cars but do as you see fit.
Crank sensor?
If check engine light is blinking that indicates a missfire.
Did you check for codes?
Could also be a bad AFM lifter……if you get a missfire code on AFM cylinders 1,7, 2 or 6.
This happened to me with only 38k on my Vert…..No. 6 collapsed exhaust AFM lifter with bent pushrod also.
I replaced the bent pushrod and 4 AFM lifters on passenger side, then performed an AFM delete with HP Tuners.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
General Motors or Major Disappointment?
This is certainly not what we like to hear, Monterey C6. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: Monterey C6/Corvette Forums in the subject line.
www.gm.com
www.gm.com
Well the issue was a defective Spark plug. I'm glad it was nothing more serious however it ended up costing me $260.19 for one bad spark plug.
I appreciate Chevrolet customer service reaching out to me. I'll be exceptionally happy if they reimbursed my expenses since it had just gone out of warranty. Anyway I'm happy to have my Corvette back running like it should.
