Replace Radiator pinhole leak, "17 Grand Sport
Like an idiot, it dropped a screwdriver into the undercarriage? of my 2017 G.S. while changing the air filter. I usually find them with magnets and a mirror on to sticks. Could not locate.
Drove less than 5 miles from house, wife was following, and she said she saw a metalic item fall from my car taking a hard right turn @ 30-40 MPH. A few hours later, a drip, and later 2-3 OZ of antifreeze came out.
When car sits still at a slight uphill drive, no drips, after driving a few miles, it's wet under the RAD. Not a hose issue, Do I, A: buy a new GM RAD, B: Take a chance that a Rockauto part will fit? or C: Fill the RAD with crap to stop leak and get into my THERM and Heater Core? I'm 63 YO and it looks like a Dealer will do it, I don't have a lift, too many parts to remove to get at RAD. I can't SEE the hole to fillmit with J&B stuff, so ....... any advice please? RAD Is $ 311. GM and $ 169. Rockauto. Install cost should be WHAT?
The following 2 users liked this post by Tinkertech:
CorvetteMike2024 (07-15-2022),
Flame Red (07-16-2022)
I watched this YouTube:
It doesn't look too bad. One thing that came to mind is that I need to get some of those pop-clip removal tools, because they looks sweet and I like to have tools. The list of tools in the video doesn't mention it, but he uses radiator clamp pliers, like these:
https://www.autozone.com/wrenches-pl...ers/607069_0_0
I have used similar pliers for years and are a must-have, because they will save you a lot of time and frustration. In some cases, it is almost impossible to get the clamp off without them.
I agree with Tinkertech. Using stop leak is not the best way to fix it. Replace the radiator. The dealer will probably charge more than $311 if they install it. I think most dealers (and independents) will frown if you bring the part. You can call the dealer and get a quote on the whole job. That may help you decide.
Corvette Junkie
Received 2,026 Likes
You have a $70,000 + or - corvette. I would not take any shortcuts. I would replace. If it were a lower value car and not a corvette , I would try stop leak.
MeanRay1 (07-16-2022)
When I owned a Euro sport sedan about 10 years ago many on that dedicated forum swore by Bar's Leaks, and most (including me) used it even when they had no leak. The scuttlebutt was that it lubricated the water pump and extended its life.
What will happen in the future? If I use Bar's Leaks Stop Leak " Liquid Aluminum" or K-Seal "all purpose (Head,Gasket,RAD)? Thermo stopped up, Heater Core not flowing property.
I do plan on keeping the '17 GS for another 100,000 miles. I was told once the leak is stopped, flush your system 1-2X to get rid of the remainder? BS or what....
Corvette Junkie
Well if your keeping it for 100,000 miles, why chinch out and put stop leak in it? If you go on long trips it could leave you stranded. Do you really want that stuff floating around your entire cooling system including the heater core? Just my .02 cents
Mostly it's how you feel about it.
Received 8,954 Likes
Bill
Several things are wrong with that. First, you need to remove the radiator which unless you are doing it yourself (which the OP doesn't seem to want to do) you might as well pop for a new radiator as labor costs are more than likely high enough to justify just going with a new GM radiator and getting a 12K/12 month warranty on the repair. The second is finding a radiator repair shop. They have just about all disappeared. It used to be any town with a 100K population would have seven or eight such shops. Now they are lucky to have one,
Bill
Bill
Do they REALLY have a StopLeak installed when it leaves Bowling Green ???
I do not remember It’s been a few years, if I had to guess I’d say it was one of the corvette engineers. Things may have changed since then as i did use it per their recommendation and it worked fine (for me)
CorvetteMike2024 (07-20-2022)
Bill
CorvetteMike2024 (07-23-2022)
That was back in the C4 days. If you changed the radiator or did a full coolant flush there were pellets you bought from the dealer that were supposed to be crushed up and dropped in the coolant reservoir as a leak preventative and lubricant.
The following 2 users liked this post by 96GS#007:
CorvetteMike2024 (07-24-2022),
ErnieN85 (07-24-2022)
