Is running 93 octane bad at high horsepower?
Right now I'm pushing 930/750 to the wheels on the stock bottom end. For fuel I'm using pump 93 + meth. The only reason I'm not on ethanol is because my tuner said the best blend I could probably do is E30 and it would be a hassle to mix all the time. Twice now I've had people tell me, not professional tuners mind you, that running 93 at my power level will blow my motor.
Is there any truth to this? Why would that be or why would they believe that?
Higher power generally means more aggressive timing/tuning, which usually comes with higher octane requirements. Your tuner (should have) tuned your car for the fuel he/she recommends. I'd follow his/her advice ahead of anyone else's.
The following 5 users liked this post by NortonCO:
Avanti (11-20-2021),
Elk (11-18-2021),
JasonVette (11-17-2021),
Maxpowers (11-18-2021),
MeanRay1 (11-21-2021)
Cruise-In IV Veteran
You should have your tuner pull timing based on the flex fuel percentage. I can run 93 or full E85 but also running Holley Port and a full secondary fuel system. Fully built 416 @ 25psi on an F1A-94 and stage 3 cam. But you can run 93 it's just a matter of tuning for it.
Check what the car has been tuned for.
NortonCO (11-18-2021)
I'm assuming your tuner is relying on the octane available in the meth to makeup for the lack of fueling capability.
In that scenario you are probably fine on 93 w/meth as long as you don't run out of meth or have a component failure in your meth kit. (and it was tuned correctly)
930whp does not sound too crazy for a H/C/I fbo +meth +2650 car as long as you tuner backed everything off a bit during tuning when they started seeing knock or fueling issues.
Even though I have secondary port injection I'm still octane limited on 93 to a little over 800whp on a 2300 setup at 14psi.
Filling up with full E85 or C85 safely gets me 50-60whp more through more aggressive timing and cooler operating internal temps just through ethanol's increased resistance to knock/detonation. (octane + valve, cylinder and overall engine cooling effects.)
If I went to a larger blower like a 2650 I would expect to safely extract more power on 93 and ethanol without changing anything else (maybe DI or PI injectors) except the tune since I already have the excess fueling capacity.
This is because the 2650 is more efficient and runs cooler which keeps detonation at bay and allows for more power given the same available octane.
There are many variables such as the size and efficiency of the blower, temperatures, altitude, other mods that alter AFR, more efficient FI delivery systems (turbos), etc. etc. that determines what is "safe".
That's why you always see variations in power in cars with the same setups from car-to-car, location-to-location, different environmental factors, fuel available.......
JasonVette (11-19-2021)
Meth + 93 is not going to blow your motor. E30 + Meth would still be better though and pick up a little bit of power. But the Meth will increase the octane and add cooling which is its purpose anyhow. I imagine you're spraying quite a bit of meth at that level. What size nozzles are you spraying with?
Received 5,238 Likes
And, it depends on what you actually do with the car, apart from whatever power it produces. You run it hard, it ups the risk. You run it hard longer, it ups the risk. All the best.
The following 2 users liked this post by Avanti:
JasonVette (11-22-2021),
NortonCO (11-20-2021)
That's all I use in my Z51
Received 1,762 Likes
ttt
Those who are telling you such things do not understand timing and the effects of meth. Listen to the one who tuned your car.
The following 2 users liked this post by ZZ06:
JasonVette (11-23-2021),
NortonCO (11-23-2021)
