2015 codes - $7eb, $7EB
Ok, 2015 LT1 - Updates are 103 TB, MSD Airforce ported intake, ARH headers Xpipe, NO CATS, has an HP Tune.
Plugged in my reader (cheap version) and the following are listed: $7E8
$7EB
Will this cause a fail for emissions?
Could not clear with my reader
Is it time for a tuner to correct?
Thanks in advance.
J
$7EB
Thanks in advance.
J
Those are not codes. Those are the diagnostic addresses of the ECM and chassis control module.
Diagnostic codes will start with P, C, B or U, and will be followed by 4 alphanumeric characters.
You need to read the codes on the scanner, then click into the $7eb module, that step is just telling you the codes are within that $7eb module. Mine listed 2 of the same modules, the top one in the list read the code, the bottom one didn't.
