HOW-TO: Install LG Z06 Cooling kit (My take)
Check your lower outermost -AN fittings. Mine were rubbing on the wheel well vent mesh and eventually rubbed through. I made a lower "brace" to move the bottom of the heat exchanger forward a 1/4" to stop the contact.
This can be solved by the direction the fittings are actually facing, you cannot move the rad more forward in the car, due to the bumper contacting it. These fittings are a "PAIN" to work with, there are specific directions they must face to avoid this.
I note this, and a bit more in my thread I linked to before.
I actually just had this happen, even though mine don't appear to be rubbing, they must have flexed around while driving and made contact enough. So despite my "positioning" this is something to watch for. You can kind of tell if this is possible by wiggling the heat exchangers. If they have enough play, they will kinda bounce around a bit.
I bought this, I think this is the fitting used....
https://www.amazon.com/EVIL-ENERGY-D...NrPXRydWU&th=1
also use aluminum mesh not steel. That way the mesh doesn’t cut through the fitting but kind of wears down also…
@BrunoTheMellow funny you should mention this, I just purchased
earlier today.
This looks to be much lower profile. I only had an issue with the one side... so ill just do one fitting for now.
@BrunoTheMellow funny you should mention this, I just purchased https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 earlier today.
I installed DeWitts race radiator and Inercooler along with a 185⁰ stat and haven't had the Z06 go into limp mode since . Before it would go into limp mode after the long straights , my best time was 2:32 at Road America ,so I do run it pretty hard , I wasn't big on cutting up the bumper. So I thought I'd try this first 🤔
Sr.Random input generator
I think you could fit something 10mm+ deeper with more compact connectors, and it could probably be another 20-30mm wider, but you'd have to tinker with mounts to center it perfectly. To be honest, I don't think there's enough space to make enough of a difference. It seems to work pretty good anyway?
If you had the GM upgraded radiator put in on the TSB. I wouldn't expect that to have changed much in the overheating. That radiator wasn't nearly as large as the DeWitts race radiator. My overheating problem was probably exacerbated by the GM tech that replaced the water pump and didn't verify how strong the coolant was. He didn't get all the air out of the system and that caused msfires on cylinder #7 & 8. When I drained everything I checked it with my refractometer and it pegged it I deluted it 50% and it still measured @ 43% what a moron. The air conditioning condenser will restrict the air more than the larger intercooler and radiator will. My Temps run considerably lower than they did before the upgrade. GM wouldn't reimburse me because a GM tech didn't do the work.
#33
Happy to hear that it all worked out well in your case. In my case, I used both Dewitt's Race radiator as well as OEM upgrade, and the results were similar: it was not overheating, but it was running very very hot, pegging 250 degrees F coolant, at which point I could not go any faster than a Grand Sport anyway : )
Keep in mind, the track configuration, driving conditions, etc. also has a significant impact, so YMMV.
