To all the vendors here!!!!!!!!!!!
Old 01-29-2019, 03:33 PM
Ghostnotes
Ghostnotes's Avatar
Default To all the vendors here!!!!!!!!!!!
When is somebody going to come out with a good set of rocker arms for the C7????????
All these high end parts...high speed lifters, 3/8 rods, high lift spring kit titanium keepers/locks/valves and what sits on top of them....stock rockers.
Old 01-29-2019, 03:46 PM
subieworx
subieworx's Avatar
Do you see them breaking?
Old 01-29-2019, 04:13 PM
Mike@DiabloSport
Supporting Vendor
Mike@DiabloSport's Avatar
Is the LT rocker much different than the LS rockers that have performed amazingly well at high power levels?
Old 01-29-2019, 05:22 PM
2014stingrayjoe
2014stingrayjoe's Avatar
both Jesel and T&D have them for the LT engines
Old 01-29-2019, 06:23 PM
FYREANT
I'm Batman..
Pro Mechanic
Support Corvetteforum!
FYREANT's Avatar
you have links to these?
Old 01-29-2019, 06:49 PM
Ghostnotes
Ghostnotes's Avatar
Yes much different.
+1
That is the only thing holding me back.
I might need to be more specific though..... a good set of shaft mounted like the T&D heavy duties.
Just checked T&D and they have nothing and left a message with Jesel. The "LT" that T&D refer to are the Vortech/LT1 heads.
Just got a reply back from Jezel.
I'm guessing shaft mounts are out for obvious reasons. I paid $1400 for my LS Comp cams/T&D shaft mount rockers. Plus they had the lubricating system. Going to try to contact T&D as well just to see.
This is really high for pedestal...
DavidI have attached a link below. The rocker with hardware is $245.00 each.
https://www.enginelabs.com/engine-tech/cam-valvetrain/pri-2017-jesel-puts-the-lt1-and-lt4-on-a-pedestal/
Apparently he was absolutely correct.
Here is T&D
The part number for this set is 15014, price is $1430.00. time frame right now is right at 10 weeks from time of order.
I was told last year they had no plans.....obviously that's changed. Going to look for pics.
Last edited by Steve Garrett; 01-30-2019 at 08:14 PM. Reason: Merged Posts-please use the Multi-Quote button in the lower right hand corner (the middle icon) to make your responses to multiple people look like this!
Old 01-30-2019, 09:39 PM
2014stingrayjoe
that is in fact correct part number for the t and d. best bang for buck. jesel is nice but over 3k and molson is about 2500. now you know!!!!
Old 01-30-2019, 09:56 PM
Ghostnotes
Ghostnotes's Avatar
I had the TD rockers on my G8 they were built like a tank and i took it to 8500 all the time. The rockers are my missing link. Everything else can handle those speeds in my C7 but for now i wont go past 7k
Old 02-04-2019, 04:55 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,232 Likes on 775 Posts
the oem rockers are great just like in the lsx stuff. only reason to change is if going solid roller.
On my personal shop/race car i run oem rockers with the trunions upgraded and rev to 7600 and make 1500.
FYREANT (02-04-2019)
Old 02-04-2019, 06:36 PM
Ghostnotes
Ghostnotes's Avatar
I dont trust them for high lift/high speed duty. Seen too many times where stock rockers and lifters fail.
Old 02-04-2019, 07:58 PM
Supporting Vendor
correct i wouldn't run an oem rocker past 635 lift, who said anything about lifters though? we run johnson's here.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 02-04-2019, 08:13 PM
Ghostnotes
Ghostnotes's Avatar
I said high lift,not lifters.
As far as lifters,I'm running tbe same.
To To all the vendors here!!!!!!!!!!!
Quick Reply: To all the vendors here!!!!!!!!!!!
