MTI C7 Aux Fuel Sytem Kit
Old 11-16-2018, 06:08 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Default MTI C7 Aux Fuel Sytem Kit
MTI’s new low side supplementary fuel system for the C7 Corvette solves the low side pressure drop issue with modified direct injected C7’s and those running E85 fuel. Fits all C7 model Corvettes (Stingray, Grand Sport and Z06). Easy installation with step by step instructions including everything you need to install this kit on your C7 Corvette. Includes high output OEM quality Walbro fuel pump, black braided lines cut to length with all fittings already attached. Custom wiring harness with plug and play weather pack connectors for ease of installation. The included MTI fuel pump control module automatically activates the fuel pump under engine load and has an integrated test button feature to check fuel pump function. The MTI fuel system kit also includes at no extra charge, a drill bit and tap for the fuel tank feed fitting, E85 compatible thread sealant as well as fuel line disconnect tool to help properly drain the fuel tank and install the fuel pump at the rear of the car. For those looking for an easy to install package to improve their low side fuel system output, the MTI C7 fuel system is the solution.
The Price is $1000 plus shipping. Call the shop or buy threw MTI.store
Thanks,
Billy
Old 11-26-2018, 10:54 AM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Bump
Old 11-28-2018, 12:03 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
This is the link to the kit.
Thanks,
Billy
https://mti.store/products/copy-of-a...sport-corvette
Old 11-28-2018, 09:53 PM
Matthewstorm
Matthewstorm's Avatar
What is the purpose of this?
Old 11-29-2018, 09:58 AM
C7&7
C7&7's Avatar
To supplement the high pressure fuel system with another pump T'd into the fuel line. Very common thing to do when reaching the 800-900 rwhp mark and needing more fuel.
Billy@MTI (11-29-2018)
Old 11-29-2018, 10:25 AM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Power adders or going to E85 will tax the lowside fuel pump. This adds flow to the lowside fuel system.
Thanks,
Billy
Old 12-10-2018, 06:43 AM
BlueDevilZ51
BlueDevilZ51's Avatar
I have a C7 Stingray with an Edelbrock E force making over 550whp on 93. If I wanted to go E85 would this kit be all I need to adapt my stock fuel system for fueling E85?
Old 12-10-2018, 10:24 AM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
You will need LT4 Hp Pump and injectors. At 550 your tapped on fuel.
Thanks,
Billy
Old 12-10-2018, 10:28 AM
BlueDevilZ51
Thanks,
Billy
okay, thanks
Old 12-13-2018, 10:31 AM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
okay, thanks
Welcome
Billy
Old 12-28-2018, 01:39 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Bump
Old 12-29-2018, 05:43 PM
brightc6
brightc6's Avatar
Great dealee, awesome customer service!!!
Old 01-02-2019, 01:35 PM
0Billy@MTI
Former Vendor
Billy@MTI's Avatar
Thank you very much!!
To MTI C7 Aux Fuel Sytem Kit
Quick Reply: MTI C7 Aux Fuel Sytem Kit
