Strength of stock differential output shafts"stub shafts"
What type of power do some of you guys have that these stock"stub shafts are holding up too,"DRAG RACING GUYS"lol.. yeah I know the spider gears are weak but besides that anybody running wavetrac with stock studs shafts ... or it's a must to do 300m shafts after the spider situation Is taken care of???? "ELSD DIFFS".. I think shafts might be little stronger in non elsd diff..
Man, it’s apart and on my bench. I say call Jeremy and get them on the way...Mike S had the wavetrac with elsd stock shafts and broke one. Don’t end the the day on the first pass over something that could have been upgraded while it was apart
I know they ain’t cheap, stock up on peanut butter and jelly and don’t order the steak for a while
Ain’t nothin’ about a race vette cheap my brother
After doing my modified diff/spiders, I broke one of my stock stubs at around 920rwhp. Replaced with the DSS 300m but haven't made any passes yet.
Only 2 got sent to rpm that where not broken, ANT got one and I got the other. We are doing 4 c7 spiders, and both shafts will be .804 dia. And they will have the 300m shafts
John
John
I have the rpm diff with the wave track and broke the 300M 2 weeks ago and I those are the 300m from the drive shaft shop... Now they are using the stock stub shafts in the wave track units. Tim King has ones that are 30% stronger than the 300m from the DSS
Supporting Vendor
The DSS stubs are junk. many of us gong fast with these have broken the DSS units. Tim king has a stub set we are going to be testing that looks promising. I wish we could fit a 9'' on the A8 that would be the ticket.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
The following 4 users liked this post by Cordes Performance Racing:
I think you need to call Tim King for them and have a shop install the stub shafts into the unit... I ended up selling my wavetrac and built a8 for a glide and 9"... Super happy I did....
Who can I send my diff to and get the 4 pinion setup installed? have a complete extra diff.
I'm Batman..
Pro Mechanic
I have a 4 pinion setup for sale, what kind of diff do you currently have? Also, FYI, nobody can build it for you. There were a finite number of them made and nobody is currently making them.
