My 2014 will not start
Location: Retired Suffolk County Police Dept NY South Carolina
I went on vacation and forgot to put the battery maintainer that came with the car as an option.
I pushed the start button and it turned over slowly.
Then I hooked up a regular charger and it took the charge but when I pushed the button it would not even crank. I noticed a message that said something like theft deterrent system needs service.
Is the some way of reseting the system to get it to turn over again.
I forgot to mention that I stuck the key into the hole in the steering column but it did not help. Any help would be appreciated, I really do not want to pay to have a mechanic drive to my house and I do not want to tow it.
When a battery goes below a critical voltage level (like what happened during your cranking attempt) it will often create operational "glitches" with some of the modules. I would disconnect your battery and connect the charger and let it have time to fully charge. While the battery is disconnected it is likely the impacted module will reset itself and the problem will disappear.
If you are in a hurry just disconnect the negative battery cable for about 10 minutes but then ensure that the charger/booster is well connected to your battery for the next start attempt to make sure that system voltage doesn't drop too low during cranking. If your battery charger doesn't have significant current capacity to assist during the start I wouldn't try this because the voltage will simply drop too low again. The direct injected engine requires a few revolutions to build up sufficient fuel pressure so it will crank longer for a start and this will be a greater drain/strain on your battery/charger combination.
My charger is the type you see in service stations. It is similar to this one but mine is over 30 years old
Your starter should have enough capability to start your C7 after a brief refresh via charging but it would still be safer to fully charge it overnight and maybe still leave it connected in the boost position for the initial start.
Hopefully the disconnect/reconnect and charge will solve the problem. good luck!
Rodger
Rodger
Rodger
Rodger
The theft deterrent system will disable the starter but hopefully the disconnect/reconnect will allow it to reset.
You might also try your other RKE remote and perhaps place it into the steering column pocket in case your RKE battery is going out. But I expect the issue occurred because of a voltage drop while trying to start the car with a nearly discharged battery.
My 2014 had a similar problem and my battery was not run down. Mine started after about hour. Brought it to a dealer that has a very well known Corvette Tech on staff. He did a complete diagnostic and everything turned out OK. He thinks it went to Diagnostic Mode. He told me if it happens again (which it has not) get out of the car and close the door then reenter. With foot on the brake, press the starter button. It should start up. Have not had a chance to check out his remedy.
By the way I forgot to mention that I have the 7 speed manual so I will have to push on he clutch and brake
If you have let the battery go completely dead, I would just replace the battery and go from there. Once completely dead they are never the same. Have you even checked the voltage across the terminals to make sure you don't have a dead cell?
similar issues for us. Our 2014 has 71k miles. the battery is fully charged. if I push the start button, click and nothing.
put the RKE fob in the steering column, side note, only 1 remote will reset. Unfortunately, I had the non-RKE fob with me while out of town.
Took 2 hours for the tow truck to get to me... ugh. But I digress. This morning, we disconnected the battery. Reconnected it after a hour or so. I pushed the start button, click....
put the RKE fob in column, did the reset as directed, pushed start and varoooom!!!
I am thinking the starter is failing. We know it is not the fob batteries as we replaced them yesterday.
Question for the C7 experts, in your opinion, do you think the starter is beginning to fail?
Mine failed at 20k miles. I was shocked it failed so soon. I was getting ready to tow it to the shop. Decided to get under the car and the starter smelled burnt. It was pretty easy to change even with my 2" headers.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,832 Likes
2015 C7 of the Year Finalist
3 year old thread? Please start a new thread for your issue and thanks!
Elmer
Elmer
