NPP on base C7
NPP on base C7
does anyone know if wiring for NPP option is installed on non-NPP
C7 cars. Friend wants to install NPP exhaust. ECM probably won't have
the programming but he can add a mild to wild.
Thanks for any help.
Go Canes!
Ernie
The wiring is not there. The aftermarket systems are his only choice.
Akrapovic makes a control kit that allows use of the NPP exhaust on a C7 supplied without it: http://www.akrapovic.com/#!/car/prod...37&yearId=4241
Ernie
Ernie
Ernie
I think the actuators are electric on the C7 (unlike the C6), so it seems it might be possible to just run a manual switch to the actuators to close them when you do not want them open.
The C6 system uses an electrical solenoid to control vacuum to the actuators.
Looks like the add on controller system uses a CAN (Controller Area Network) sniffer to detect the car's signal to close the valves, which triggers a relay to provide the electrical signal..
Unfortunately, the actuators are not a simple on off circuit. See this thread: https://www.corvetteforum.com/forums...-retrofit.html
I also am looking at this change to my non NPP stingray. It appears there are two ways to go to switch the NPP actuators on or off. One forum member has designed a solution that uses an external switch and an outfit out of Europe has a design that integrates into the CAN bus using a sniffer circuit and operates like the factory system.
You can get the switch design for around $170 usd and the CAN bus version for about $555 usd. I think plus shipping on both. PM me if you would like additional details. Most of the details are available on other posts on the forum.
The CAN bus version is only available when you purchase the exhaust system provided by the same company.
Ernie
Ernie
Ernie
The HRE/Akrapovic rep told me the kits were not available for purchased separately, only as replacement items for owners with the Akrapovic systems on their vehicles.
Apparently not correct. RPI designs list these kits for sale.
2nd Gear
I reached out to Theta the creator of the module to retrofit base C7's but have not heard from him. Does anyone know if he is still selling the boards , connectors etc?
I reached out to him a few times without any response, I think I read somewhere that he was going to have to under go chemo. he may not be around anymore. I hope that's not the case.
2nd Gear
https://www.corvetteforum.com/forums...y-exhaust.html
Tech4882 (11-27-2016)
That's good to know. At $555 for the kit it's good to know it works on the NPP exhaust before you invest. Here's the RPI link;
http://www.rpidesigns.com/shop/item....c-control-kit/
