Let's talk C7 spring rates
2) Remember, both the 06/gs and the 07's spring rates were chosen with the thought that they would be used with mag shocks that act to stiffen the suspension.... so stiffer is better.
1) I would use the 07 springs as the are the stiffest and the were selected for tires that are close to what you would put on the z51.
Sometime you use stiffer springs because you have more downforce. Otherwise you trash your tires. It's all about balancing act.
If stiffer was better, folks would be racing 460Hp gocarts.
I believe GS springs are FE6 springs.
FE7 spring parts are:
Rear Spring 23344290 (90 vs 88)
Front spring 22892343 (43 vs 42)
Keep in mind GS Z07 only comes with stage 2 level of downforce, while Z06 Z07 has higher downforce with stage 3.
As Tadge said, a stage 3 GS would result in unfavorable top end speed and GM didn't feel GS needs it.
With GM's fine tuning of 2017 GS front end via front stab bar, I'm curious if 2017 Z06 has a revised stab bar...?
If you mount tires with more grip than what came stock, you need to increase the spring rates. Sway bars are for balancing the car, not controlling body roll.
Sr.Random input generator
I do have the stage 3 aero (APR's replica). I'll drive car back to back with middle element on/off to see what its impact is to cornering and front straight trap speeds.
IIRC, GS/Z07 uses stiffer Z06/Z07 spring for the rear, while front is always the same.
Please go back and look at the stiffness table on page one. GS std and Z07 both have the same "soft" front spring rate, but bigger stab bar.
Idea of using softer front with big bar and stiffer rear, which is what GM is now using with GS is all explained in detail here:
http://www.longacreracing.com/userfi.../SoftSetup.pdf
Some excerpts:
The big bar soft spring set up does seem to work better, at least to date, on tracks with less banking. Why? Banked tracks compress the suspension due to the higher speed and additional travel. Banked tracks keep the nose piece close to the ground throughout the turn. Sway bars simply do less work on banked tracks as cars compress into the banking where as on flat tracks the roll is much more evident. The aero advantage is created by the banking. Certainly the big bar soft spring setups can still work with banking but you can see that the banking creates some of the benefits naturally. Thinking out the dynamic movements on flat and banked tracks will help you take advantage of the positives on all track types.
Big Bar Soft Spring Benefits:
• The car reacts quicker
• Roll centers and move less in the turn creating stability
• More grip due to Aero advantage
• Lower center of gravity throughout the turn
• More forward bite
• The added front sway bar rate enhances entry confidence
Where the big bar soft spring set up works better:
• Experienced drivers and successful teams
• Flat tracks seem more conducive to the principles but it can help anywhere
• On tracks with reasonable grip
• With tires that can take some punishment
Eli-Z06 (08-19-2018)
I just don't get that statement. If an S2000 can make time using a giant wing, how can a simple spoiler type aero be too much? All the very fast C5 and C6 track cars I've seen had wings bigger than my coffee table. I'm yet to see any fast C7; we'll probably see them popping up soon. I think it's made that way since they sticked wth the softer spring up front, and it's not stiff enough to support higher aero (which obviously cannot be dynamically done through MRC tune).
Here's the full article:
BIG BAR SOFT SPRING SET UP SECRETS
Should you be jumping into the latest soft set up craze for late model asphalt cars? Maybe you will find more speed or maybe you won’t, but either way understanding the dynamics will help to improve your corner speeds.
The soft set up is designed to take advantage of spec tires that are now commonplace. New age tires put up with more abuse and resist blistering as compared to those from the tire war era. Taking advantage of aerodynamic benefits created by body designs that are sleeker is part of the soft set up as well. Maximum stability is created through less side body movement. By understanding the goals of the big bar soft spring set up you can find ways to improve your lap speeds.
The new soft set up buzz involves a big sway bar to control roll and the softest front springs possible that are just big enough to keep the nose from bottoming out. Ironically, the new buzz has been referred to as the "soft set up" when in actuality there is much more spring rate added by the sway bar verses the reductions in the front spring rates.
Higher shock rebound rates are needed to control the added spring rate introduced by the bigger front bars. Added rebound helps to tie the body in the lowest nose position possible. Typically, the package is coupled with rear springs that are stiffer than traditional set ups. The stiffer rear springs can be vital to the so called soft set up for a variety of reasons which we will analyze.
Why soft front springs? A big benefit is getting the nose down on the ground. Air that gets under the car creates lift which is just about always bad. Getting the nose down creates more airflow over the entire body creating more down force literally pushing the entire car into the track promoting more corner grip. While the front springs are softer, the big sway bars are adding a large amount of overall spring rate to the car. As you go up in bar diameter the rates increase exponentially.
Why a big bar? Since the soft front springs let the nose settle down to the pavement we then need to keep the body position low throughout the turn. A big sway bar is utilized to resist roll and it adds spring rate as the car enters the turn. We are trading roll rate from the front springs and moving that work to the sway bar. We are also adding overall spring rate and taking advantage of the aero grip created by modern day body designs. The benefit of the big bar is that it helps to hold the left front down as you roll through the turn and on acceleration. With the sway bar holding the nose piece low throughout the turn more air flows over the entire body surface creating additional down force and grip. The car being held down low allows for less overall side travel through the turn, hopefully resulting in more overall stability and consistency. With the suspension linkages traveling less after corner entry, the dynamic changes are controlled and the car becomes more predicable throughout the turn. Minimizing travel in the center of the turn is a big piece of the new package and the added bar rate enhances driver confidence. In addition, the center of gravity is lower in time with when the corner loading is at its maximum point. The big bar creates a quicker responding car that feels more stable due to the elimination of nosing over on the RF.
To enhance less lift at the left front tire additional rebound is utilized in the shock package. Shocks with more rebound and less compression are a common practice when utilizing the soft set up. Once the nose settles during braking, keeping it down there becomes the goal. The added rebound helps to keep the car flat and added rebound controls the spring oscillations as well. Shocks need to control the spring rate included both in the springs and in the sway bar. As always, the teams that best match up the shock package will go faster for a longer period of time. In fact, matching the shocks to the overall set up package, track, temperature, and driver style is still a critical piece of the puzzle. Remember, there is generally more spring rate to control and these forces need to be considered when matching your shock package to the new concepts.
Controlling the body angles in the turns helps to create consistency. You can imagine that if the nose piece were low on entry and then lifted on exit that you are introducing variables resulting from the continually changing body position. Constantly changing linkage angle changes have an effect on the handling as well. Lift at the nose and squatting in the rear reduce down force at a varying rate throughout the turn. Nose raise creates additional front lift and rear squat moves the spoiler out of the air for less rear down force. With traditional set ups, the front aero lift and the rear spoiler moving down occur at the worst possible times. Obviously more rear spoiler on corner exit would be good for forward bite and a lower nose piece throughout the turn is going to create more speed. These two gains are included in the Big Bar Soft Set Up. A more constant body position allows the driver to chase the car less as the aero change throughout the corner is more consistent.
With the soft front springs, big front sway bars, and additional rebound the front end is now doing its part. Big rear springs pitch in to keep the rear spoiler up in the wind for more exit grip and forward bite. Added right rear spring rate holds up the right rear corner helping to keep the left front low promoting more air flow over the body for more overall down force. The big bar soft spring set up gets the front and rear to work together for maximum aero balance and grip.
So now that our soft set up has the body flat, the nose low, the rear spoiler held up in the wind and body movements controlled promoting consistency, this now brings new chassis parameters into the process.
We can look at each corner of the car and think about new dynamics created by the soft set up as compared to traditional set ups. Each corner is affected differently and we can think about the new challenges and consider the adjustments required to make the big bar soft spring set up work best. All adjustments must work together. A complete package is the goal and you must tune the entire car to achieve improvements. A traditional set up that is completely dialed in would be much better than a big bar soft spring set up that did not address all of the variables.
LF
The left front starts out at the tech approved minimum ride height. The soft front springs allow the front end to drop under braking and the big bar, big right rear spring, and added rebound hold the left front suspension for maximum nose drop on entry and throughout the turn. You can see that the added downward travel will have an effect on the camber patterns and adjustments need to be made. With the LF A-arm being shorter than the LF lower control arm your car will lose camber under the left front suspension compression created by the big bar soft spring set up. The shorter upper A-arm decreases in length faster than the lower control arm causing camber loss. This camber loss is opposite of traditional set ups that promote camber gain during upward body movement.
The soft set up usually requires high amounts of LF static camber as compared to traditional set ups. Top crew chiefs check the camber at ride height and then recheck the camber at the anticipated corner ride height. The camber in the center of the corner is most important and static settings need to be adjusted for optimal camber at the center of the turn. The new approach creates static camber settings that seem radical as compared to traditional set ups.
RF
The right front starts out at the approved minimum ride height and drops during braking and moves down even more when the body rolls. Our soft set up with a big bar and high rebound actually allows for more RF drop from static ride height to the middle of the turn. The additional amount of travel created allows for more camber gain as the RF A-Arm is shorter than the lower. Our new big bar soft spring set up will require dramatically less static camber allowing for more optimal camber in the center of the turn. You can see that experimenting with the camber curves and static adjustments require a change in thinking from past ideals.
LR & RR
Bigger springs in the rear create new thought processes as well. More spring keeps the spoiler in the air allowing for more down force and less downward movement of the body. With less movement you may experience the need to vary anti-squat adjustments. Again, our thought processes are different with the new set up. You may find that you need to run more split in the panhard bar to get an equal amount of rear steer as the stiffer springs coupled with the stiffer sway bar create less roll. You might want to experiment with more trailing arm angle as well to help rear steer the car through the center of the turn. The whole mind set relating to the rear linkages needs to be based on less travel. It is very common that you will run considerably more RR spring rate than LR with this set up.
The soft set up should really be reserved for those that already are consistently fast and have a handle on traditional adjustments. In order to achieve improvement it really helps to understand the dynamics behind all adjustments from springs to shocks to weight adjustments before experimenting with the unknown.
Once the decision is made to experiment with soft set ups experience has shown that it is an all or nothing proposition. The soft set up is an entire package versus just a spring adjustment. Moving up one sway bar size and changing 25 lbs. of spring rate is not really embracing the concept. The new bar rates and spring choices are eye popping as compared to traditional set ups, an open mind to these ideas is truly required.
Suspension design over the past twenty years is virtually the same from Nextel Cup to Saturday night. If that is the case then why is this big bar soft spring set up gaining popularity? There are several things that have changed during that time allowing the concepts of the new set up ideal to be possible. First off the new bodies are very sleek as compared to old body designs. Aero grip is something that has increased steadily over the years. In addition, most people are running tires that run longer. Harder longer wearing tires that do not fall off much have become common. The aero advantages really help to create grip in harder tires. While the aero advantages are vivid, the new era tires are the main reason that the new set up concepts are to be considered. Further, big bars speed the loading to the contact patch and the new harder tires are up to the challenge. We also have more horsepower and more RPM as compared to twenty years ago and more forward bite makes that horsepower more effective. Shock technology has improved and better shock control reduces tire temperature increasing tire wear. Current shock adjustability allows for more grip by keeping the tire on the ground.
If you ran super soft tires it makes sense that the big bar soft spring set up would be fast for qualifying but the tires would fall off or blister on a long run. Blistering tires were common in the tire war days but for now it seems that most divisions are currently being supplied harder, longer wearing tires that easily go the distance allowing more stress to be placed on the contact patch. It makes sense that bigger front bars and more rear spring rate transfer load to the tires more quickly. The point is that sleeker bodies and better, harder tires have made the bigger bars and soft front springs possible. In addition, radial tires create a lot of grip through superior side wall design further enhancing the big bar soft spring concepts.
• More forward bite
Drawbacks:
• More stress on the tires
• Lots of trial and error testing to identify new baselines
• Sway bar neutral setting and preload becomes critical
• Camber settings become more critical
• Your old set up book will be junk!
Like all new things trial and error testing is a big part of the process. The teams that best understand the dynamic movements will be able to maximize the benefits. The learning curve is dramatic as the big bar soft spring set up breaks many of the rules of the traditional mechanical grip set ups. It is important to remember that while the racing community has labeled this concept the "soft set up" the reality is that there is more spring rate in the car both front and rear. Many of the dynamics change from past ideas and you will find that keeping an open mind to what the driver and car want will result in changes that seemed insane just last week. Testing and persistence just might find you more speed and push you softly into victory lane.
LF
RF
LR & RR
• More forward bite
Drawbacks:
Kamran, I could not disagree more with the big bar/ soft spring setup. Sway/roll bars reduce grip. People that say otherwise do not understand how they work imo. Let me explain how I think they think a sway bar works and you tell me where I am wrong.
A car goes into a right hand turn(rht) and the weight shifts to the left side of the suspension. The left side springs compress and the lower control arms compress. The LCA's push the swaybar up on the left side. The swaybar's wanting to remain flat pulls the right side LCA's up......here is where I think the "big bar/ soft spring" falls on its face. What are swaybars doing to the inside tires in a turn ? They are lifting them. Now, we know that down force increases grip....what does up force do to grip?
Now, I am not saying that we should not run swaybars, I do think that you should run as little a bar as you can and I think you should use the non drive wheels do a lot of the body roll control and make the drive wheels as independent as possible....
The big bar/ soft spring may work in NASCAR but since when did NASCAR have anything to do with cars?
Per the article, trick is to have stiff rears (the article addresseing your particular point). Please re-read "LF" above. When turning right, the stiff LR springs, and added rebound resist RF from lifting, when combined with stiff sways (resisting rolls) and more nose aero downforce forcing front to stay level and composed with LF. The premise of the concept "is" to keep the nose (L & R) glued and forced down.
Suspension set up and development is not as simple as following three basic rules with modern "everything". As the article suggests, I'm also trying to keep an open mind to the concept, although I haven't tried it...yet. I also believe that GM is also "already" going in that direction with the GS set up (just compare GS w/Z07 with Z06 w/Z07 springs and stab bars), in search of record lap times for the magazines, in the hands of pros.
I'm certainly willing to keep my mind open and learn and willing to re-educate myself. I'd stop learning right now if I thought I was an expert and didn't keep an open mind. Otherwise we'd still be stuck racing Bugatti's with POSITIVE camber! Although I'd give my pinky for one of those!
Also not sure if the article is only relevant to NASCAR, when flat track turning could apply to anything non-banked.
I look at it like this.....swaybars make your independent suspension less independent. think of it like this, put a 6 inch thick swaybar on the front of your car, how independent is your suspension going to be? How is that a good thing?
Next, if you are a real suspension tuner, you do not look at what the factory does because they design under steer into every car because of law suits....car leaves road nose first, drivers fault...car leave the road tail first, car makers fault.
Knowing that, looking at spring rates without looking at motion ratios for the springs is kinda silly imo. If you are looking at the raw spring rates and saying that means anything I can not agree. I had a civic that had 225lbs/in spring in the front and 440lbs/in in the rear...the weight distribution was 60/40 f/r.....the problem was the front motion ratio was .91 and the rear was .588....so you had to have more spring in the rear because of the difference of the suspension designs from the front to the rear. Same is the issue in the corvette.
...and so the world still goes on around!
2017 GS front spring = 2017 GS w/Z07 front spring = 117 Nmm
2017 GS stab bar = 28mm/4mm; GS w/Z07 stab bar = 32mm/5mm
The only time a blanket statement like "stiffer is better" is on the wedding night!
Happy New Year.✌
Happy New Year.✌
#33
I think you guys are both right. Soft setup is actually not too soft, and even in that article, it makes it clear that it might not work on every car, and it also works better on flat tracks (elevation changes would upset it more than the benefits with the soft setup).
Now GS Z07 would also benefit from dynamic valving of MRC, but I'm sure it will work better at certain tracks over others.
I'd personally prefer stiff setup that gives more confidence, but it's not always faster, which is fine : )
#34
In my quest for learning modern suspension, I asked if I could send my shocks to be re-valved or shims restacked, and I was informed there are none with MSRC, only mag fluid which hardens or softens...
#35
It's all good. I learn every time I communicate with members of similar interests!
I love it, too. After all the other cars, I thought I started figuring it out, but this car has thought me a lot yet again. We'll see how things work out next season.
#36
I'm sure it could theoretically be re-valved, but not the way it's done traditionally (pressure). I think different nozzles and fluids can be used for changing the default (not-electrified) level of dampening/compression. IMO, your question on that was valid : )
There are no such things dumb questions, only dumb answers!
#37
Resurrecting this really old thread. Does anyone have the part number for the bigger GS Z07 front sway bar? I can't seem to find it in the online parts catalogs.
#38
I think it's same as T1 kit's front sway bar. I might have it in my Z51 build thread.
#39
The following 2 users liked this post by MSR:
2019CMGZ51 (01-05-2020),
Poor-sha (05-24-2019)
#40
GS Z07 was great in tight transitions, very responsive. I’ve owned both GS, Z07 was much more planted. Will be interesting to see how it does with stiffer front springs, as opposed to the big bar-soft spring theory talked about in this thread.
