If you are talking putting this in a c6 z06 it has been out for a long time now.
Actually, it hasn't. There have been gears for the base C6 rear end but not for the larger, stronger Z06/ZR1 rear end. RPM has been the supplier of fortified base C6 rear ends but require you to switch to the weaker case when installed in Z06's.
For all of you that are waiting, please understand that there is serious development work taking place on 3.90 and 4.10 gear sets for the C7. Until we have a proven gear set we are going to remain quiet.
Also, for any of you who have a C6 Z06 and/or ZR1, 3.73, 3.90, and 4.10 gears are being developed for your diffs also.
This has been talked about for over A year now.I seriously doubt that this is going to happen.
Probably would be just as good to put the Z06 trans and rear in your car.
