What track wheel & tire setup are you running?
St. Jude Donor '15-'16
JV
Originally Posted by X25
Thanks, great to hear that the sizes work! Do you have magna ride? I bought a Z51 without magna ride, which comes with stiffer springs. Combined with the much stiffer T1 suspension's shocks, I'm hoping squat should not be an issue.
Assuming you have MR: Z51 with magna ride comes with softer springs to provide a comfortable ride at the street or even when softness is needed at the track, and the shocks stiffen at the track to make up for soft springs. This works well, until you replace the tires with stickier ones and push the shocks more than they are tuned for. If not already, you should consider buying the DSC module, which would help you match the shocks' tune with the traction you have from those tires.
Looking forward to trying out my setup at the track : )
Sr.Random input generator
Check it out:
https://www.corvetteforum.com/forums...uspension.html
Controller:
http://store.katechengines.com/dsc-s...px?Thread=True
If you want to go all the way:
http://store.katechengines.com/dsc-s...ocks-p521.aspx
Controller:
Check it out:
Controller:
Controller:
I appreciate the help!
Run the non-run flat MPSS in a +1 size on a spare set of factory Z51 wheels. I go through about two sets of front tires to one set of rears. Eight track days on the front tires, about one and a half hours of track time each day. Compromise alignment between street and track.
Of course tire wear would vary widely depending on the track and driver, but it will give you some kind of idea.
OEM size is:
FRONT 245/35R19
REAR 285/30R20
So +1 size would be?
FRONT 255/35R19
REAR 295/30R20
What is the advantage of running the +1 size? More grip?
All RTF wheels are custom manufactured using aerospace grade 6061-T6 forged aluminum per order.
This allows us an advantage in being able to offer any offset, width and finish when you order any of our RTF Track Spec or Modular Series.
Available sizes
18x8, 18x8.5, 18x9, 18x9.5, 18x10, 18x10.5, 18x11, 18x11.5, 18x12, **18x13**
19x8, 19x8.5, 19x9, 19x9.5, 19x10, 19x10.5, 19x11, 19x12, **19x13**
20x8, 20x8.5, 20x9, 20x9.5, 20x10, 20x10.5, 20x11, 20x12
21x8, 21x8.5, 21x9, 21x9.5, 21x10, 21x10.5, 21x11, 21x11.5, 21x12, **21x13**
** Limited availability **
Specifications
* 1pc Forged Concave MonoBloc Contruction.
* RTF Motorsport Series wheels are manufactured using 6061-T6 aerospace-grade forged aluminum for maximum strength-to-weight ratio.
* Special pocketing is standard to minimize unsprung mass and rotational inertia for maximum performance and handling.
* CNC machined to all custom specifications.
** Centerlock applications available. **
* Bead seat knurling available on all Track Spec Series wheels.
* PTP weight reduction ( Stage 1) applicable.
* CTP weight reduction (Stage 2) applicable.
* CTP.v2 weight reduction (Stage 3) applicable.
* Machined to clear all Big Brake Kits applications.
* OEM TPMS compatible.
* 2 Year finish warranty.
* Limited lifetime structural warranty.
Profiles do vary based on car and fitment
If you have any questions on any of our designs please feel free to send us an email directly to Sales@RTFWheels.com or a PM.
RTF is currently offer media discounts on 3 of our new MonoBloc Series designs.
Track Spec-M10, Track Spec-10 * CTP Edition *, Track Spec-5 *CTP.v2 Edition*
and our all new RTF Track Spec-Spyder
Media discount available to limited Corvette chassis.
RTF-10SL
Size: 18 x 11 / 19 x 13
Finish: RTF Track Red Centers w/ RTF Brush Titanium Step Lip
Car: 2015 C7 Z06
RTF-10SL
Car: 2015 C7 Z06
RTF-10SL
Car: 2015 C7 Z06
RTF-10SL
Car: 2015 C7 Z06
RTF-10SL
Car: 2015 C7 Z06
RTF Track Spec-5
Size: 19 x 10 F / 20 x 12 R
Finish: RTF Brush
Car: 2016 C7 Z06
RTF Track Spec-5
Finish: RTF Brush
Car: 2016 C7 Z06
RTF Track Spec-5
Size: 18 x 9.5 / 19 x 11
Finish: Matte Black
Car: 2016 C6 Z51
RTF Track Spec-5
Finish: Matte Black
Car: 2016 C6 Z51
RTF Track Spec-5
Finish: Matte Black
Car: 2016 C6 Z51
RTF Track Spec-5
Finish: Matte Black
Car: 2016 C6 Z51
RTF Track Spec-5
Finish: Matte Black
Car: 2016 C6 Z51
RTF Track Spec-10
Size: 18 x 9 / 19 x 12
Finish: Gloss Black
Car: 2016 C7 Z06
RTF Track Spec-10
Finish: Gloss Black
Car: 2016 C7 Z06
RTF Track Spec-10
Finish: Gloss Black
Car: 2016 C7 Z06
RTF Track Spec-10 * CTP Edition *
Size: 19 x 9 / 20 x 11
Finish: Gloss Black w/ Brembo Red lettering
Car: 2016 C7 Z51
Car: 2016 C7 Z51
RTF Track Spec-10
Size: 19 x 10 / 20 x 12
Finish: Matte Black
Car: 2016 C7 Z06
RTF Track Spec-10
Finish: Matte Black
Car: 2016 C7 Z06
RTF Track Spec-10
Finish: Matte Black
Car: 2016 C7 Z06
RTF Track Spec-5
Size: 19 x 11 F 20 x 13 R
Finish: RTF Dark Brush Titanium w/ Lava Sapphire inner
Car: 2014 c6 ZR1
RTF Track Spec-5
Car: 2014 c6 ZR1
RTF Track Spec-5
Car: 2014 c6 ZR1
It looks like the reason for the +1 size is that they don't make the non-ZP tires in the 245 and 285, but they do make them in the 255 and 295 sizes. But, I don't see $4-500 difference. I see $250 max difference based off Tire Rack website.
On my 2015 Z51 I'm running Cray Spiders 18x9.5 +56 (front) & 19x11.0 +76 (rear) with Hoosier A7 275/35/18 (front) and 315/30/19 (rear). This are simply amazing on the track and are night and day over the stock tires (Thanks Alex @ TheSpeedDepot). For pads I'm using Carbotech XP20 and XP12 pads (Thanks Adam@Amp'dAutosport.com) and running Motul660 brake fluid. Finally, Spiegler SS Brake lines. Otherwise the car is stock except for cosmetic items.
Is your car lowered on stock bolts? Or just the way it left the factory?
