Sport Cup 2 on Z51 wheels
Hi guys,
I have some 265/35/R19 and 295/30/R20 Sport Cup 2 tires that a friend of mine gave me last year, barely a few hundred miles on them.
Will they fit my Z51 ? I'm lowered on stock bolts.
How are they compared with the R888s ?
Regards,
Michael
Regards,
Michael
That is the sizes I run on my '15 Z51.
Mine is lowered on stock bolts also.
Don't know how they compare in size with R888's.
Cruise-In II Veteran
Cruise-In III Veteran
Someone posted..
I also have a Z51 that I track. Someone who runs those posted that they DO rub if you are lowered on stock bolts, I wanted to use them but I didn't want to raise car and I want ZERO rubbing, esp on Track. Some guys run them on the street seemingly with no issues, esp if they aren't lowered. Good luck and report results I would love to run those but don't want to rub and want to leave car lowered
I run 255/295 MPSS lowered on stock bolts. Slight rub front and rear. I have a few spots that are rubbing and a couple that have rubbed enough to create a small hole in the liner.
on the stock z51 wheels?
That's cool!!! if this is true, I am going to upgrade to those sizes!
I had the rears installed today...no rubbing so far.
My first impression is that they hook less then the PSS...but maybe it's still cold outside...
Everything I have heard is that you have to heat up the Cup's pretty good before they will hook. Keep us posted with your results. For a street tire the PSS non-runflats seem like a worthy option..
