Base dyno pull/aFe install
Just a thought, you should do pulls on the dyno right after the install, then again in a few hundred miles after it's given a chance to learn/adjust, just to see what, if anything, the difference is.
Steve_R (12-29-2015)
Received 3,291 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Edit: If the ambient air temp in the shop isn't within a few degrees for both runs the results will be pretty meaningless.
Then I get to drive it again long enough to let the ecm re learn
If you want to keep your stock tune, at least have the people at your shop record performance data during the dyno run (air fuel ratio is one of them).
A local shop installed long tube headers+high flow cats, then ran a test dyno run.
I gained 20 hp. My car was running too lean and the tuner changed various settings.
After a proper tune, I gained an additional 13 hp.
I realize my car, elevation, performance adders are all different.
My engine will last longer properly tuned. That day was "warranty destruction day".
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Stock tune is staying put. That is the reason for going with mid length headers and high flow cats. The placement of the o2 sensor bung on the ARH units is equal to where it would be using the oe cast header and the first set of oe cats. The entire objective is to not eradicate my power train coverage.
NCM Lifetime Member
I will have to ask Matt if it might cause a code doing pulls right after the header install. My preference is to follow Steve's suggestion which is basically that of aFe. Give the system a chance to learn the changes.
NCM Lifetime Member
Agree, that would have provided the most information. I'll be interested to see the dyno results as well. I've always been skeptical of the manufacturer's HP claims on CAI install with no other mods. Note they always claim "Up to" xx HP, which means it could also be 0 or 1. Even if a CAI alone gives 10 HP I don't believe anyone's butt dyno is sensitive enough to feel it.
I'm anxious to see the results.
NCM Lifetime Member
so am I. It kind of sucks knowing the headers are at their shop but they can't do the install next week. I'm sure my s/o would have something to say if I brought them home for the weekend ........
NCM Lifetime Member
Yah, too cold to spend much time in the garage right now. In addition to the ARHs, I also have a catch can, E85 conversion, Z06 grille, and competition seat conversion to install. It will be a fun time in the garage one it warms up some.
#33
NCM Lifetime Member
Never could figure that out. I grew up on the western slopes. We'd be skiing in shorts on Ajax in Aspen and Denver would be like an ice cube.
#34
I occasionally get a check engine light with ARH mid length headers caused by inefficient cats. It's the P420 code. I look it up using HP tuners and clear it
#35
NCM Lifetime Member
#36
Cats are from ARH. I installed the headers last spring. When I got the first CEL after only 150 miles, ARH sent replacement cats with O2 bung extensions. That seemed to work but occasionally the CEL still pops up. Usually after a restart 1 hour after a cool down and restart. I may go a few thousand miles between CEL.
So I don't have to bring my laptop every time I go on a long drive, I've order the new Kiwi 3 from PLX, a tiny wireless device that plugs into the OBDII port so I can monitor and reset any CEL code from my iPhone.
#37
NCM Lifetime Member
Interesting. Have you spoken to Steve or Nick in tech support at ARH about this issue ? They really need to know. I say this as they has assured both Matt at 21st Century and I that they had cured the cel issue.
Last edited by MikeyTX; 01-02-2016 at 10:41 AM. Reason: spelling/sentence structure
#38
NCM Lifetime Member
Sincerely,
Nick Filippides
Owner/Manager
American Racing Headers
880 Grand Blvd
Deer Park, NY 11729
PH. 631-608-1986
Fax 631789-4157
nick@americanracingheaders.com Mike
#39
NCM Lifetime Member
Well, Matt did the dyno pulls with the aFe on first thing this morning. I haven't seen the printout yet. I asked about doing pulls right after the header install. Total waste of time and money was his response. Because they have to pull the main power feed to do the header install it would make no sense he said, for the exact reason you mention. The entire system will now have to relearn everything. Damn good thing there's a deli just down the block. This is going to be a long day
bigpete105 (01-06-2016)
#40
