MGW shifter installed. Questions, knob sits high..
MGW shifter installed. Questions, **** sits high..
Wife got me MGW shifter for xmas so I installed it today. Pretty straight forward install. I have a few questions though.
I like the stock shift **** so kept that and when I put it back on the MGW shifter I noticed two things. It sits higher now. Maybe the straight up and down is why it's higher? Just seems off to me. Did anyone else notice this? Is there a way to get it to sit lower? Why isn't this shifter angled like the stock? The stock shifter has a sight bend to it which feels more natural in my hand.
Next I noticed in some DIY pictures that the MGW shifter seems to sit at a angle in some pictures. Mine does not. It is perfectly straight. Why do I see some sitting at a angle? For instance if you scroll about half way through this post you will see theta's pictures and his sits side ways.
https://www.corvetteforum.com/forums...post1586582711
Which version of the mgw did you get? The older style one or the one with the exposed stick?
Basic question, are you sure you installed it correctly?
I'm also assuming the picture where it's not straight is when the car is in 2nd or 4th gear
Received 1,694 Likes
St. Jude Donor '15
I think what happened was MGW changed the way the shifter is aligned. Originally you could get it with the alignment at 12 like what you have now, or offset at 7 like what you see in Thetas pictures. The reasoning was to avoid the hand grip. At some point they realized that the offset wasn't needed so they did away with that option and now the **** sits straight up and down. At least I'm pretty sure that's what I read, I could have the story wrong somewhere along the way, but I do know they only supply it the way you have it.
Thanks guys. To answer some questions from Muuhaha, yes I installed it correctly. It's pretty straight forward and I followed the directions on MGW site and from Theta's post for good measures.
I do not believe there is different models for the C7. When you go to MGW's site you select the shifter and in the drop down you select your model corvette. That is all there is to it.
Here is a a few pictures for reference. I know the **** pictures don't help much but I'll post them. I really wish this shifter was angled like OEM. It's my only complaint at this point.
I should also add that I did not get the lubrication they showed in the videos and DIY post. The piece you lubricate already had a good amount of grease on it from factory so I moved forward with installing. Not sure why I didn't get the lubrication.
John,
Did you notice it sat straight up and down too after your install? How is that other stick compared to the one you had before? Looks like it has a angle to it which I would prefer. Also looks like it sits lower. Does it from the stock ****?
The shifter was then redesigned, with the lever placed in either the 6:00 or 12:00 position. That accommodated the few customers - myself included - who wanted to be able to position the lever further away from the body. That's why you see the differences in some of the early installation photos versus the later installation photos.
Buy a spare shift rod from MGW, heat it and bend it to the angle you want. Should not be a problem. I bought a spare and had it re threaded to fit a **** I have owned for years.
OP, your **** does appear to be sitting higher than those in pics posted here and higher than mine, which I recently installed. A couple of reasons your **** could be higher: 1) You didn't thread the upper shaft all the way into the gold-anodized receiver block before tightening the lock nut. 2) You may not have pushed the **** all the way down on the shaft. I had to use considerable force to get the **** to seat all the way down on the shaft before installing the lock screw. I could see how it would be possible to do this since the **** is so tight on the shaft that you may not need to tighten the lock screw and still have the **** secure enough to shift with it.
If all this is done correctly on yours then you may need to either modify the MGW by shortening the upper shaft to lower the stock ****, get a shorter **** or go with the flat stick MGW since that version seems to be lower. I have a flat stick version also that will be going in my C5 project car soon so I look forward to seeing how that compares to the round shaft version in my C7.
Patches, the **** is seated all the way down as I have the screw in there. However I could check the upper MGW piece to see if I can get it down more.
That metal washer on the bottom is just to protect that gold plating.
Picture of the MGW shifter installed on my 2013 427 (LS7).
It is a Great rock solid unit. I'm not sure they offered the flat stick back when I installed mine (which was shortly after I purchased the car new in late 2013). I also installed the round "gripper" shifter ball.
Notice the comparason of the stock unit in the second pic. No comparison. The stock piece is rather flimsy.
I just installed the MGW on my Z06 and I agree that it does sit higher. I measured the stock height at various points of the disassembly and the MGW sits about 1/2 inch taller with the handle screwed down to the lowest setting (with both washers removed). I actually ordered an extra C7 and C6 handle. The C6 handle has two holes and the bottom one is a bit lower, but you have to drill out the plastic notch in the C7 shift **** for it to slide down farther. I think MGW use to ship the C6 handles with the C7 kit until they made the C7 handle with one hole. Will report back after I get the handle and try it.
I'm going to see if I can angle the extra C7 handle I'm getting.
CDH76 (02-04-2016)
I finally got around to modifying the handle so it sat a little lower and was angled
https://www.corvetteforum.com/forums...e-for-mgw.html
