Forged stock cube shortblock??
Plan is to go with a 2200r sc in the future want to go ahead and forge the bottom end. Just wanting to see what everyone is doing spec and price wise on these? I'm looking to get some nice forged Pistons (leaning towards wiseco) and some Callie's billet rods. Should I go "h" or "I" beams?
Been told stock crank is good? May push the car to 900-1000rwhp
Any advise/opinions are welcome thanks!!
Received 1,763 Likes
Give wiseco a call ask them about the new piston set they have for these c7 ls1. I was talking with them in sept at BG KY at the holley LS fest..
Stock cubic inch is your best bet. Ive built and owned plenty of "strokers" but the stock CI engines always last longer. Less stroke, better rod/piston geometry, beefier pistons.
The Gen V block has the same issue as the LS block does when it comes to stroker cranks. At the bottom of the stroke the piston skirt actually comes out of the bore and it allows the piston to rock. This causes premature bearing, piston, and cylinder wall wear.
At the end of the day a stock ci vs a stroker will normally make the same peak power. The difference is that the stroker will make substantially more torque. This is a good or a bad thing, when it comes to getting traction on the street without a real tire, its a bad thing. No matter what you do, you will want to look into stepping down to a 18" rear wheel with a nice drag radial with some sidewall. 18 will clear the factory brakes and it will allow you a decent tire selection. I get a good chuckle when I see these guys trying to get traction on a 19/20" wheel, its a waste of money.
marcouvo (11-01-2015)
Didn't realize that happened, but makes sense. Makes me feel a little better about not going to a stroker when I had everything apart.
The following 3 users liked this post by SilversledC7:
Man knows what he is talking about for sure. I would love to have a single turbo set up done by him with a small cam in it.
Platinum Supporting Vendor
The Wiseco big pin pistons are for stock rods. For some stupid reason the pins are always tight and the rods need honing.
Their pins are .945 and the rod is .944, if I remember correctly.
I sent them a stock rod a few months ago show them. Hopefully they have it straight.
I usually use Wiseco pistons with a set of Molnar Technologies rods. Tom Molnar really knows his stuff.
I keep those pistons on the shelf in case I'm in a hurry.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
