Z51 Option Description
This seems crazy, but I cannot find a detailed description of the 2016 Z51 option. Can't find it on the forum, can't find it on GM sites.
Can anyone point me in the right direction?
The Z51 includes
Larger 19-inch front and 20-inch rear wheels
Dry sump oil system
Electronic Limited-Slip Differential
Larger front brakes (13.6 inch vs. 12.6 inch) with black calipers
Specific shocks, springs and stabilizer bars
Differential and transmission cooling
Unique Aero Package that reduces lift for high-speed stability
Michelin® Pilot® Super Sport® ZP summer-only tires4 that are aggressively tuned to provide outstanding handling, grip and road-holding capability
Available Magnetic Selective Ride ControlTM and Performance Traction Management
HD Cooling
Dry sump oil system
HD Cooling
Z51 Performance Package, includes (J55) performance brakes, (J6A) Black-painted calipers, slotted brake rotors, (Z52) dry sump oil system, (FE3) Z51 performance suspension, specific shocks, springs and stabilizer bars, (NPP) performance exhaust, (XFJ) P245/35ZR19 front and P285/30ZR20 rear tires, (Q7S) Silver-painted aluminum, 19" front and 20" rear wheels, performance gear ratios, (G96) Electronic Limited Slip Differential (eLSD), (KNR) rear differential cooler, transmission cooling and an Aero Package
Here it is again with RPO numbers.
2015 was the first year NPP came with the Z51, in 14 it had to be added ($1100) if you wanted it.
Added into the Z51 it came out a little cheaper, I found this out when I ordered my car last year.
http://www.corvetteblogger.com/2014/...rice-increase/
One more point about the Z51 Coupe and Convertible starting $1,000 more than in 2014’s final prices. In 2015, the Z51 will now include the NPP Performance Exhaust which previously was a $1,195 add-on. So for those that wanted a Z51 Coupe or Convertible and the NPP exhaust, now they are saving $195 over 2014’s prices.
