Hydraulic Clutch Fluid
I was perusing the online owners manual in regards to recommended clutch fluid... I already knew it took Dot 4 brake fluid, however, it gives a specific gm part number to use in the states and Canada, Eh! My dilemma is my ongoing shifter issue I first want to try to resolve changing out the fluid first. The simple question I have is... Has anyone used any other fluid other than the recommended gm part number?
I appreciate the reply. Think it'll hurt to mix fluids? Example... Extract all the fluid out I can using the turkey baster method, then refill with "x" fluid.
GM fluid comes in tiny bottles at a very expensive price tag, you can get a quart of Dot 4 for around the same price.
You shouldn't worry about mixing fluids they are all compatible, just buy a quality brand Prestone dot 3 and 4, is what I buy
Yeah, I called the GM parts department as asked for their clutch fluid... 16ozs of Dot 4 is $17 wholesale. I just wanted to make sure it isn't a "specific" fluid and not regular Dot 4 brake fluid. Thanks for your reply.
Received 8,956 Likes
On the C5/C6 GM recommended Super DOT4 Brake Fluid for the clutch. The only Super DOT4 fluid on the market is from Pentosin. You can buy it on Amazon. A few auto parts stores sell it as well. From what I can tell it has a lower viscosity as well as the DOT4 temp range. You can view the spec sheet here: http://www.pentosin.net/specsheets/P...SuperDot_4.pdf
http://www.pentosin.net/f_brakefluid.asp
Bill
Bill
Bill
Bill
The clutch reservoir only holds about 2 oz., so you can get multiple changes even with the GM 16 oz bottle.. I went ahead and just bought the GM fluid. (but my dealer does give me a discount, so I paid $6.39)
TEXHAWK0, The key word here is "if" I change mine every 3000 miles or so. I use the GM dot4 and I change it 6-7 times until it comes clean. I don't like reusing a open container of brake fluid, so when I change the clutch fluid I'll use the whole container. (16 oz)
Counter intuitive for my needs... I tend to be a very high rpm shifter most of the time. I'd prolly need to change mine out more than that. My car has 15k on it right now, so I think it should've already been done a couple of times... Maybe this weekend.
http://www.seinesystems.com/BrakeFluids.htm
