Just throwing this teaser out there.......
Old 08-11-2015, 05:50 PM
0ProChargerTech
Former Vendor
ProChargerTech's Avatar
Default Just throwing this teaser out there.......
What makes more RWTQ then a new C7 Z06?
What makes more RWHP then a new C7 Z06?
Has no heat soak, no fade, and strait hauls the mail....
On just 7psi of boost, on a standard C7....
One of the BETA C7 i-1 ProCharger cars spotted on the set of a reality TV show in FL.
Old 08-11-2015, 05:54 PM
T/A KID
T/A KID's Avatar
Details?
Old 08-11-2015, 08:22 PM
NoOne
NoOne's Avatar
From the odd shape of the SC is it electric?
Old 08-11-2015, 09:11 PM
kiley2418
kiley2418's Avatar
Programmable I-1 looks very interesting... Subscribed for more details
Old 08-11-2015, 09:24 PM
motomanvette
motomanvette's Avatar
Why don't you go to Carlisle and I'll let you use my car to showcase your new products!
Old 08-12-2015, 07:11 AM
jerry07dx
jerry07dx's Avatar
two times the cost of a standard procharger. hell I just want a standard one LOL
Old 08-12-2015, 10:01 AM
0ProChargerTech
Former Vendor
Bout the same as a quality screw style unit.
With the boost curve to match it, and about 14 other advantages.
The car in the photo laid down 643 ft lbs of TQ at the wheels @2600 rpm
Old 08-12-2015, 10:24 AM
blue_bomber697
blue_bomber697's Avatar
Received 1,296 Likes on 479 Posts
2018 C7 of Year Finalist
On 7 lbs of boost? Jesus... Can't wait to hear more about this thing.
Old 08-12-2015, 10:34 AM
SquatchMachining
SquatchMachining's Avatar
I like the innovation but when I saw this thing at SEMA two years ago I could not believe how big it is. Do you have a weight comparison of this vs say a F-1X?
Couldnt you essentially get the same results or very close by setting up say a standard blower for max impeller speed at your desired redline and then using a wastegate and a good programable boost controller to ramp up very quickly on the low end but limit peak boost on the big end? Or is this unit capable of even higher impeller speeds at lower RPM than that would achieve? Im assuming it may be.
Its a A+ for creativity in my book, I just could never get past the size of it nor have I seen anyone really push one to the limit to see if it is capable of making more power than a Whipple unit or even a less efficient TVS2300 unit.
Can you share more information as far as its operation goes and peak power it has produced?
Old 08-12-2015, 12:31 PM
black98c5
black98c5's Avatar
^^^ I'd be interested in seeing what this thing could do on a higher boost setting (~15+psi).
Old 08-12-2015, 12:38 PM
SquatchMachining
I was thinking more like 20-25....
Old 08-12-2015, 03:12 PM
black98c5
black98c5's Avatar
That would be ideal, but I doubt theyll push that blower to that level unless some other shop does it...hope I'm wrong. I used to run ~23psi on my F1C. that thing moved out.
Old 08-13-2015, 11:19 AM
StingerBG
StingerBG's Avatar
A little confused and this may be a newbie (to the world of SC'ing) question.... But if the SC itself is programmable and you can switch to different modes which will put out different psi of boost...wouldn't you still have to re-tune the car each time you switch modes? Sorry for my ignorance...just trying to figure this all out. May be worth holding out for this over a standard centrifugal SC depending on what all goes with it!
Old 08-13-2015, 03:35 PM
10mm_
10mm_'s Avatar
St. Jude Donor '15
Slick!
I'll stick to my $800 nitrous kit
Old 08-25-2015, 07:01 PM
0ProChargerTech
Former Vendor
Weight is bout the same as any roots/screw
Power levels are limited to around what a D1SC is.
Efficiency of a centrifugal.
Boost curve of whatever you want
Effectiveness and lack of heat soak from an air to air.
And can be turned up/down and curves changed from inside the cabin.
There are some youtube videos that explain more.
For a guy thats not doing a built motor, and maybe just a cam, it really is the of the coolest forced induction options out there, that can be bolted on in a garage. (no fab)
Old 08-25-2015, 07:03 PM
0ProChargerTech
Former Vendor
Tuning via MAF and Speed density takes care of all those concerns.
I daily drive one on my personal vehicle with a LOT of miles on it, and switch modes all the time. (run low boost, when I fill up with sketchy gas out of town while towing, run more boost when I am at home and know I got good 91 in my area)
Old 08-25-2015, 07:14 PM
thegame
thegame's Avatar
Why does that corvette have a mini keg in the motor !!
To Just throwing this teaser out there.......
Old 08-26-2015, 11:27 AM
tomlink
tomlink's Avatar
Back in the WW2 days of HP propeller-driven aircraft, engine manufacturers developed 2-speed (and sometimes 2-stage) centri superchargers to optimize boost performance for both high and low altitudes. For us, the issue is high and low rpm performance.
Currently, the centri solution is to "pulley-down" to increase low rpm impeller speed (increasing low rpm boost), and then add a restrictor plate to limit excessive high-rpm boost. While a simple and elegant solution, the engine is wasting HP overspinning the impeller at high engine rpm.
It appears that the CVT in the i-1 enables the centri to vary the impeller drive ratio (impeller speed) for optimum boost at any rpm.
On paper, it sounds like the killer FI solution. Looking forward to seeing more dyno/strip/sotp results.
Old 08-26-2015, 05:55 PM
cheapthrills
cheapthrills's Avatar
Definitely interested in this.
Old 08-26-2015, 06:09 PM
0ProChargerTech
Former Vendor
That was the first time anyone wanted one polished.
Usually they are black and "hide" a bit more.
But nothing wrong with a mini-keg, and nothing wrong with HP.
Quick Reply: Just throwing this teaser out there.......
