Where to start!!!
Cruising
Where to start!!!
I Have a C7 Lt 1. I bought it basic to spend more money on hp. So my question is what is the best bang for the buck an my goal is 750-800 RWHP. An yes I want a SC an also open to meth injection. It is a Manual. How much power will the bottom end handle. I will not be taking to a drag stripe to hook up like crazy I just want a big Hp street driven car to play with. So any info you can help me with would be great I am from IN but willing to travel to any shop that is the best deal for the money. Thanks for the info in advance
Bottom end is proving durable. Quite a few well over 800whp so far and I have not heard of a boost related failure yet.
750 is a pretty easy goal if its a 7 speed car.
ECS Supercharger Kit, Alky Control Methanol Injection, ARH Headers.
That alone will bang on the door of 750whp.
More power than that is a Cam and blower pulley away...
Cruising
What cam would you recommend an also If I change my headers an go to long tube. Do I need to change the total exhaust. if so what is the best out there so many products its hard to figure what is the best.
I would contact ECS regarding a Cam if you use their kit.
As far as exhaust goes, ARH is pretty much the nicest out there with solid results and customer service. It will bolt up to your factory mufflers...
Just look on the forum and see who is building lots of 700-1000+whp cars. You will find one kit that sticks out. ECS.
Other systems have achieved high numbers as well, but its not as common.
If you act right now during the black friday sales I would not be suprised if you could get the Blower kit, Meth kit, and Headers shipped to your door for well under $8000..
Cruising
Ok Im ready to order my headers So Im going to get long tub. So what size do I need like 1 3/4" 2" or 1 7/8" an do I want with or without cats. Thanks so much for the help just don't want to buy twice.
I like the fact that Kooks offer the High temp 2200+ degree silver coating on theirs but have not seen that on the ARH system anywhere?
Coating is gimmicky. That being said if you live any metro place there is probably 20 places to coat them. I would take uncoated arh over coated kooks any day.
Who informed you that coatings are a gimmick. Sure they wont net you a discernable hp increase but they do lower underhood temps dramatically which helps in generating power and keeping things consistent. The ceramic coatings reduce radiated heat and in all seriousness is almost a necessary upgrade for FI engines especially since heat soak is much more prevalent in them.
I have all my parts coated. Does it help, yes, does it make a huge difference, not really. People seem to think it is some magic and coating makes heat issues go away. The only coating that really does amazing things is the swaintech white lightning. All the other ceramic stuff has a small effect, but I like it because it keeps the parts looking good and prevents corrosion.
In my experience, they do not lower underhood temps dramatically. They do it very slightly, and unless the cost is low, you are better off wrapping the pipes if you really want lower temps.
This pretty much sums it up.
Premium Supporting Vendor
first thing I recommend is a nice exhaust upgrade to get all the new found air out! Checkout the TSP long tubes. At under a grand for fully polished 304 stainless with 3" x pipe the package is extremely hard to beat! It's also the longest primaries available on the market & makes killer torque gains!!
http://www.texas-speed.com/p-4408-te...ad-x-pipe.aspx
Supporting Vendor
Here is a thread on our headers we make that lashway motorsports did an independent review on
https://www.corvetteforum.com/forums...7-headers.html
