Vibration at high speed
Doesn't this sound like the problem is out of balance rotors? These rotors are two piece, correct? I think they have a problem with a batch of these rotors. I think you may have found the problem. If they weren't the problem, then the vibration should have stayed the same.
Whatever the case, if they changed rotors and the vibration changed (in this case it got worse), that has to mean that the new rotors are not balanced if the wheels and tires are ok. I would have a machine shop check the rotors for balance.
Been racing/tracking C5s for a decade... changed many rotors... never balanced one ever and never had a vibration related to one. The only time I've ever had a bad vibration in my car was when I mounted some race scrubs and didn't balance them. Bad vibration over 100... balanced them and they were find the next race weekend.
I run two piece floating rotors, but that doesn't really matter. If GM had a bad batch of unbalanced rotors you'd probably have more chatter about vibration issues on the forum. My money is on the torque tube couplers being defective.
To the OP, did you ever see what happened when you shifted into neutral and disengaged the clutch? That would isolate the driveshaft.
HTH, and have a good one,
Mike
Oh, I didn't know that. I thought they were free.
OK, I'm being sarcastic. Sorry. I was just going on the report that when they changed rotors, it got worse. If that is really the case, how else can you interpret it?
Since the rotors are manufactured differently than previous rotors, I don't see how previous experience is useable here.
If it were my car and nobody could figure this out, I would take the time to eliminate this as a problem. You could probably do it yourself for only a time investment, but even if you bought new rotors, if you drive the car hard or track it, you're going to need rotors eventually anyway.
Since these rotors are cast as two separate pieces and then joined together, is it completely unreasonable that a problem with the orientation between the hat and the rotor could develop?
Mike
We can also be talking about harmonics where a few natural material frequencies align with certain operational frequencies which could explain the 90 mph thing. Without very expensive equipment, it could take months to find the problem otherwise.
Soichiro Honda was the first to consider acoustics and Reynolds in engine design and Fred Lanchester was the inventor of the harmonic balancer for his engines in 1889. These problems have existed for 300 years. You still learn 300 year old formulas at engineering school. Fred's cars were also the first with interchangeable parts, first production line, first dampers, first epi-cyclic or planetary transmissions, long before Olds in 1902.
Have a good one,
Mike
#33
Further updates. The car right now is sitting at a performance auto shop which has a dyno. Dealer is still going back and forth with GM with what looks like a trial and error game.
The latest I got today was the dealer provided two new wheels and tires from a new car (although we tested this already on a road test) to reconfirm that the vibration is not due to my wheels and the vibration again persisted.
the car was then put up on a car hoist, wheels were removed, and the car was sped up in the air and again, vibration persisted (although the shop owner said this was a very unreliable way of testing because the car is in the air).
I am losing patience where I feel GM is not doing enough in trying to help me out even though it is still under a bumper to bumper warranty!! I am losing my patience
#34
Patience is one of those skills learned through painful experience, hang in there!
Mike
#35
My money is still on the drive shaft couplers... her's the guts of my C5 race car... The C7 is similar... there are rubber couplers at each end. If one fails or if the bolts came loose...
Entire torque tube assembly, drive shaft is inside
Front end that slides into back of the crank
Back side
Back side
#37
At high speed the prop shaft is still turning when out of gear. I'd test the following:
1. Stopped in neutral - Engine and drive shaft are turning
2. Stopped clutch in - Only engine turning
3. At speed push in clutch - Engine disconnected from drive shaft and trans
4. At speed put in Neutral - Engine and drive shaft disconnected from trans (sort of)
5. At speed put in neutral and push in clutch - Drive shaft now free-wheeling
If the vibration dissipates more quickly in scenario 5 then it's the shaft bushings.
#38
#40
