Boost Gauge
Boost Gauge
For those who have installed boost gauges..which gauge did you go with and how did you mount/route to the cabin? Was having a carbon fiber dash a consideration in where you mounted?
From the photos the Z06 model replaces the engine temperature gauge with a boost gauge. Since the existing temperature gauge isn't terribly active/responsive you might consider the Z06 approach to keep a clean install look.
On edit: take a look at the 7 and 17 second points on the youtube video
