Race-Only tires for a C7 Z51
Hey guys -
I am looking for recommendations for a race-only set of wheel and tires for road racing. so far the TSW Nurburgring in 19/19 looks to be my best fitment with these tires:
backs
305/35-19 HOOSIER R6 (-0.7% )
295/35-19 hOOSIER r6 (-1.2)
Fronts
235/35-19 Hoosie R6 (-0.6%)
265/35-19Hoosier R6 (1.2%)
Let me knoe of an othr options you have tried
backs
Fronts
please keep looking
Hey guys -
backs
Fronts
backs
Fronts
If I may make a suggestion, TSW Interlagos may be something different and if you're picky are a bit lighter. Are you looking to autocross, road race?
Edit: Stupid question, you said road racing.
Yeah, a better selection of tires can be found in 19/19 or 18/19.
And 265/305 front/rear tire sizes are a good choice on 9.5"/11" wide wheels. Wheel offsets should be about 52mm front and 74mm rear. (Well, a 59mm front wheel with a 5mm spacer is 54mm.)
If you want to increase front tire size while holding 305 rear tire size then the Oz Superleggera III can be found in 10" to 11" front wheel widths listed under the C5. Then only an 11" rear wheel can be found listed under the C6.
If wanting the 285/35-18 and 325/30-19 tire sizes, that calls for a 10" wide front wheel and an 11.5" wide rear wheel. Wheel offsets should be 56mm front and 79mm rear. Lowering to tuck the tops of the tires is required and rear brake duct clearance might be a problem.
Finally, the RS-3 Version 2 and the AD08 R have Corvette tire sizes up to 305. Pilot Sport Cup 2 is about the only choice for 19/20 tire sizes. But all of these tires are an alternative to R-comps
RE-11's have a lot of sizes too in the 19's. Toyo R888's are relatively diverse too but those will wear out FAST.
I think a nice setup would be 305/30-19 rear, 275/30-19 front. If you have to put a 305 on a 10.5" wide wheel (you'll also gain a TINY amount of tire wall doing this too), it's by no means the end of the world but 11" is ideal. 275 really should be on a 9.5".
Former Vendor
I am running Cray Brickyards
18 x 9.5 front with 275/35/18 Pirelli take offs from World Challenge
19 x 11 Rear with 295/30/19 Pirelli
Whole set out the door with tires $1,800
Will have them on the track next weekend.
Thanks!
The Cray 18x9.5 fronts/19x11 rears I ordered just came in... and the front rims do not clear the Z51 calipers! (and yes I removed the OEM pads w/ balance weights). The rears fit (barely... just clearing the bearing mount).
The problem is the reverse barrel design.
C5 Z06 wheels made for GM by Speedline in Italy, 18x10.5 on all four corners, fitted with Nitto NT-01's in 315/30/18 all around. A lot of rubber, lightweight, and well priced. $300 per wheel, $300 per tire. Can rotate tires around to even wear.
X25 (08-29-2016)
Doesnt that chew up the brake ducts?
Received 2,379 Likes
Edit: I found the wheels. Still curious about clearance. How about lock to lock? I know it shouldn't be an issue for racing, but curious.
I think, is it MTI? Is running the exact setup but said they were rubbing the brake ducts :/ Im confused now. I would love some NT01s on this setup to use for the autox events I do almost once a week. Would sure be better than chewing up the regular tires
Sr.Random input generator
I've been running 275/30/18F, 305/30/19R, and it feels like I need more, especially at the rear (can't put power down fast enough).
Wheels are 18x10.5 ET52 (4mm outwards than yours; should provide a bit more ducitng clearance), 19x11.5 ET83 (this should be OK. OEM is 19x10 ET79 IIRC).
Are you still running this setup? I am about to order 315/30/18 for front, 325/30/19 for rears (NT01); excited!
At the last VIR full event with temps in the mid 90's I threw P12F0 & P12FD codes.
Will GM replace these if you have LT's & x-pipe installed?
Will removing fuse 32 eliminate the CEL?
Don't mean to hijack your thread, so PM if you'd like.
Thanks!
Any fender rubbing up front?
(When I put 315's on my present wheels (18 x 10 CCW's, offset: 58), I can't keep them from hitting the lip of the front fenders)
Thanks.
