How-To: Remove/Replace Lower Rear Bumper Fascia
Old 02-21-2017, 10:57 AM
walleyejack
walleyejack's Avatar
Originally Posted by The_Gretz
This is great information as I'm considering pulling the cat-back exhaust to have the tips powdercoated. Removing the lower fascia doesn't look difficult at all.
well if you follow the link above, it isnt, all you have to do is figure out how to take the whole clip off and then is easy to seperate. heh
it can be removed easily with out removing the clip.
lotti (10-30-2017)
Old 06-04-2017, 05:14 PM
gpuglisi
gpuglisi's Avatar
In Post #4, after removing the rear bumper fascia grills, the tabs must be released. The instructions call for the use of a flat bladed screwdriver. Can anyone provide some detail on this, which way is pressure applied to release the tabs?
Old 06-28-2017, 08:24 AM
vetteZpilot
vetteZpilot's Avatar
On each reflector there are 3 tabs 2 go one direction and 1 goes the other,
I was able to work it off by going back and forth after getting the first outboard one released with plastic pry tool.
Old 06-28-2017, 08:28 AM
vetteZpilot
another thing the reflectors are marked Right Hand / Left Hand if you forget witch is witch the rear grills are marked the same and they only go in one way because of shape use them as a guide to RH and LH
Old 09-24-2017, 02:42 PM
sccaracer46
sccaracer46's Avatar
Originally Posted by 2016 vette
I searched everywhere for information on if the entire bumper has to be removed on the 2014-2016 rear end to repaint the bottom half. Well good news you don't have to do very much to get it off.
1. Remove the ten 7mm bolt on bottom.
3. Remove the two 10 mm bolts above the exhaust.
4. Pop off the mud flaps and remove the two 15 torx screws on each side.
5.On the bottom edge of bumper by the wheel pop the bumper loose from the upper part of the facia separating the two colored sections.
6. Now you can put your hand under the bumper and pop the red reflectors off the back.
7. Lastly remove the two 10 mm bolts on each side where the reflectors were and you are done. The bumper bottom will fall off in your hands.
Total time is less than 30 min and you can do by yourself. Then you can get the bottom painted. Installation is easier wish I had video taped it but you won't need that anyway. Good luck. Now mine is color coded to rest of car
Thank you for your information! I had some damage from a rear-end encounter and was just ready to take it in for replacement next week. I decided to check GM prices and decided to replace it myself. Well, the removal was ALMOST a piece of cake! I followed your instructions exactly, but something was still holding it. I found that there are two additional 10 mm bolts behind the license plate! They are deep set just outside where the license plate attaches. Once, I removed them it did, indeed, drop right off!
This saved me almost $500.00! This forum is a great asset as I already installed my MGW shifter based on console removal information I discovered from the forum. That saved me over $300 quoted by my dealer! BTW, I,M 80 years old and still wenchin'!
pkincy (09-24-2017)
Old 12-09-2017, 06:56 PM
RapidC84B
RapidC84B's Avatar
Received 13,220 Likes on 6,023 Posts
Ok... so can the lower half be removed separately? Theta's pictures seem to indicate GM wants you to remove the entire fascia first?
Hawkerpilot62 (08-24-2020)
Old 12-27-2017, 06:24 PM
rv3flyr
rv3flyr's Avatar
Yep, the bottom fascia can be removed by itself. However, on my '17, it didn't exactly "fall off in my hands", as it did for 2016 vette in post #14. After following all of the steps he mentioned, I had 2 clips on the top corners of the bottom fascia that I had to release. Pull straight back, firmly, and the panel will pop off.
Warpcorps (03-18-2021)
Old 08-03-2018, 10:07 AM
16C7Z51
16C7Z51's Avatar
I just removed and re installed the diffuser, for some apparent reason I have two 10mm bolts left over??? All six and installed In going to book myself into the doctor for a checkup because I clearly have a mental issue. Lol
Old 08-03-2018, 12:32 PM
vetteZpilot
are they the ones from the exhaust opening
Old 03-30-2019, 07:48 PM
gvkooy
Cruising
gvkooy's Avatar
Do you have the part number?
Old 08-24-2020, 02:04 PM
Hawkerpilot62
Hawkerpilot62's Avatar
Default Painting Rear Lower Fascia...
What a great idea! Thanks for the idea AND the spec sheet on removal. Five years old but still relevant today. Thanks gentlemen...
Ron
Old 12-04-2022, 05:08 PM
TOBASCO
TOBASCO's Avatar
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
Thread is now 7 years old and it still is useful!
Quick Reply: How-To: Remove/Replace Lower Rear Bumper Fascia
