Billy boat bullet - need help
Installed bullets on my c7 yesterday and drove it home about 65 miles no problems. Got in today and fired her up went to a couple stores and at my last stop before heading home my engine light came on. One note for those that might can help I took the NPP exhaust off my car to install the bullets. Supposedly this system was to be installed without throwing codes. I really don't know what to do at this point any help would be great. Thanks.
I have a set on order, waiting to be delivered/installed, so this is also a question I'm interested in.
Hopefully, this is not an actual issue, but just a loose "something" on this install.
Check out this thread:
http://forums.corvetteforum.com/c7-t...ck-result.html
You removed the actuators so it thinks the system is broken.
You might try changing the engine sound management to the other setting
Between the NPP and Billy Boats - how is the sound around town and highway?
Hopefully you get the thrown code resolved.
Do the codes only happen with the NPP cars? I have a BB system on the way to put on my NON-NPP Stingray ..... Hopefully it's different? Sounds like a PITA for just a bolt on mod!
The sound to me is amazing! The NPP sounds good but the bullets are much deeper and more aggressive. Again I guess it really just depends on what you are looking for.
So is it going to hurt to drive it until I can figure out how to clear the code? Any other suggestions as to how to clear? The engine sound management is set to off already.
I would put the BB Fusion on a NPP C7.
But if the code is not some kind of lean combustion situation then it must be because of not having the NPP wires connected to something. So resistors on the wires might work
St. Jude Donor '14-'15
I didn't see this had a dedicated thread until you posted in the NPP fuse thread.
If you'd like me to help you over here, that works, as well. Just need to know the answers to the questions posted over there.
I would imagine the code is not a big issue. Only way to know what the code is/clear the code is to go to the dealer, auto parts store, or buy a scanner.
I also asked him to get the code from OnStar (about the only perk of that other than Emergency Services) and I would look into it tonight.
If he physically removed the rear actuators, it will be a CCM group code. I have a P-list sitting here waiting for the code result.
But the code is minor, and shouldn't hurt a thing - it's simply alerting you to a problem that's (literally) not there.
I have a set of Billy Boat Fusion with Bi Modul control on order, and this will be installed by my speed shop, Redline Motorsports. I assume from what I've been told, these exhaust system will work in conjunction with the driver mode software that's already in place for the NPP factory exhaust.
I certainly hope this is the case since the last thing I need is the thing chucking engine check lights at me!
I'm also getting American Racing headers, 1 7/8", and the X pipe. Along with the Green air filter already installed, this should be a cool setup.
Now there is tuning to disable the AFM but I haven't heard of any tuning to disable the NPP. I wonder if disabling the AFM would fix the problem here because when the AFM turns on that turns off the NPP.
Another idea, put some NPP muffler valves in the trunk and run the wires to them.
I assume that the BB Bullet muffler is not popping ?
This isn't too far off from what may need to be done if the signal is PWM (which I believe it is). Instead of a 'clunky' solution, though, we may be able to replicate the PWM or simply remove the computer/electrical portion of the valve and encase it in a weatherproofed material and tie it back up into the harness.
Of course - when AFM kicks in, the goal of the system is to keep the system as quiet as possible.
The NPP valves close in order for the exhaust to travel through the muffled/baffled (middle) tailpipes only.
NPP working or not working doesn't really matter except in four-cylinder mode
