Boost Gauge Showing Only Vacuum, Not Boost
St. Jude Donor '14-'15
Alright, now it's time for me to pick your brains about something.
Required info: I have two Innovate digital gauges: the MTX-L for AFR, and the MTX-D for Boost/Vacuum.
The lines are setup in the following way (see pic) per the PCV "fix" of separating the valley cover and intake manifold barbs.
As you can see, I have the T-line running from the intake manifold bard to both the gauge and the blow-off valve. This operates the valve without any issue, but the gauge will only show vacuum. When going into boost, it simply registers 0.
Here's my thought here... the manifold tap is only ever going to show vacuum since it's been separated. So... anyone have a recommendation for showing both boost and vac, or perhaps even simpler, does anyone know a good place to grab boost from?
So... Any ideas?
So... Any ideas?
St. Jude Donor '13
Technically, pressure ("boost") is in the intake manifold during positive pressure operation, so the hose from intake manifold should show boost unless there is a check valve on the intake manifold side. If that is the case it does not see boost on that side but I doubt that there is one in the int side...
So the gauge is T'd into a vac line that runs from the intake manifold to the bov?
That is a correct install, and should show you manifold pressure both in boost and in vacuum... so either the line that runs to the gauge is pinched off somewhere, or there is a check valve preventing boost from registering.
Does the BOV work correctly? If there is no positive pressure making it to the top port on the BOV it will blow open while is boost.
Vac tube to sensor is straight , un-pinched, and the sensor is sitting right next to washer fluid spout on the driver's side engine bay.
I've already done the hillbilly test - took the hose off, blew and sucked - gauge registered boost and vac values (small though they were).
I'm concerned that perhaps the wildly-loud BOV noise I was hearing today has something to do with this... Theoretically, if the valve never closed, I'd still be making boost at a greater rate than it could escape through the BOV...
Might be time to break out a mechanical gauge.
Okay, basic tests completed...
1) Gauge is fine, used mechanical to verify side-by-side.
2) No check valve on the intake manifold port - free air back and forth...
3) No leak on the BOV when off - spring is holding it tightly.
Bad news...
After reviewing the videos, it sounds like the BOV is never closing... Actually positive of it...
So that means there's no boost pressure running through the intake manifold... What... The... F...
Can somebody else with a blower or another shop take a wild-*** guess at this?
Things learned:
a) A human male can exert 2.1psi of pressure through a small air hose, and create 12in/hg of vacuum...
b) Crankcase gases are bad, mm'kay?
What a night...
Video mentioned above - listen for the boost - BOV isn't closing (try starting at 27 seconds):
Bad news...
Things learned:
What a night...
Something isn't right. You are grabbing from the correct location. Do you have another gauge to test it with?
Well, from your install thread the performance gain seems to indicate you are getting significant boost. I would start by pulling the line at the manifold tap and apply pressure to the line to see if you have a leak at the BOV control or somewhere in your line or the T you used. That small line cannot flow very much air so a leak would drop line pressure without materially affecting overall boost.
It would be a true oddball case but a defect/cut in the line could seal under vacuum but open under positive pressure creating the odd reading you are seeing.
Way back when I had my first Centri on Corvette, as I would drive in 2nd gear with throttle partially open, I could hear exactly the same sound as yours where all the boost was rushing out. This was because of the cheap BOV that came with the package. I then bought the TiAL and them install it on a new pipe and solved the problem.
I think the one I bought was like this with 11lb spring.
http://www.rallysportdirect.com/Tial...FchQ7AodfDMAuw
Check out the different springs in that page.
In the video, I could hear the sound started as you stepped on the gas with the throttle open (which means the spring in BOV is not resisting the pressure) as opposed to when the throttle is closed (that's when the spring should let the pressure out).
I bet the BOV isn't working right.
Precisely - T running from intake manifold to BOV and gauge.
Which BOV is this? And what spring pressure does it have?
In the above picture both sealing washers are on top of the fitting when one should be on each side. Could very likely have a boost leak at that fitting which is causing no boost to read on the gauge.
1 Post
Bad news...
Things learned:
What a night...
Bad news...
Things learned:
What a night...
With engine not running bypass valve should be closed. When running at idle it should be open. If both statements are true, then don’t worry about it till you can drive it. When on the road roll into throttle at ~3000RPM, you should be able to feel it close.
The bypass valve is designed to keep impeller out of surge margin - surge is a localized or full rotating stall followed by flow reversal. Or more simplified the impeller is trying to flow more than engine (downstream flow) will accept. This happens during shifts (if stick), hard deceleration or high RPM and low throttle opening…
Sorry guys, my mind has been elsewhere. I should have mentioned this was observed during my drive yesterday.
Video was an example.
I will try the seal fix and see if that's the issue seems very logical.
Sorry, only have a phone at the moment.
