*Pics* LTx Front Main Seal vs. LSx Front Main Seal
St. Jude Donor '13
Just a comparison for everyone. Here is the LT1 style seal vs. the LSx style seal. Cost comparison wise the LT1 seal is about $7 retail and the LSx is about $25 retail.
Received 2,379 Likes
So we know the problem....what's the solution????
Former Vendor
All we did was take the LS1 seal and trim it down to .300 to make it fit
seals perfect and is SO much stronger. until you hold one in your hand you don't really get how crappy the LT1 seal is
the rear main seal is the same exact seal so we are all good there!
St. Jude Donor '14-'15
Yet another adventure in cost cutting! Or, perhaps a bit more nefariously, a warning shot to those looking to slap on forced induction seeing as how these blocks are so strong otherwise.
FWIW, The LT1 seal has a pressure energized lip where the LS seal doesn't. When the LT1 seal fails is the seal coming out of its bore or is the lip blowing out? Is that used seal a failed one?
Thanks a lot. I've worked with a lot of linear and rotary shaft seals and 8 psi or whatever a blower adds to the crankcase shouldn't hurt the seal unless it is defective or improperly installed. That lip is actually supposed to squeeze the shaft tighter the more pressure is applied. Since the case is shorter than the LS seal, my first guessis some are skewed to the crank at installation.
St. Jude Donor '13
Crank case doesn't see boost. Any pressure is from leak down and making it past the rings.
Platinum Supporting Vendor
I had a fixture made for my lathe. You pop the seal in and in about 30 seconds it's trimmed and ready to install in an LT motor.
Upping the crankcase vent to 5/8" and installing an LS seal should do it.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
Seems to be a global issue this seal. Was at Redline's shop the other day and that had the same seals laid out on the bench and showed me how week that lip is.....I don't understand the logic behind GM lightening up that seal when the old seal worked fine!
Matt,
Thanks for posting those. The root of this issue is more the excess crankcase pressure then a seal although this new seal design is not helping.
Blow by in an engine is an inherent dynamic that exists. Forced induction just compounds the issue even further and when the factory PCV system is not well designed and then they use seals like Matt has show your bound to blow stuff out.
I think the return of the older style seal is a great enhancement but the pressure needs to be dealt with. We have a couple C7's down to the bare blocks and have dissected the system like a 5 grader with a frog in biology class. There are some valving issues that need to get addressed but the bigger issue is crankcase volume. I'm curious over time if the dry sump cars are more prone then wet to blow seals as the crankcase area is small. We are working on a expansion tank with built in catch can and have up sized the feed and return lines quite a bit to allow additional crankcase volume to at least leave the crankcase and not look for a place to push....in addition to the leak potentials there is also the excess pumping and windage that is going to most certainly effect power output.
Be warned that anything that adds additional cylinder pressure to the combustion chamber will increase blow by........this includes detonation. Detonation can raise cylinder pressures upward of 3000 psi and no ring set will keep it from getting into the case......food for thought.....
HT
HT
Supporting Vendor
Solutions right now are to install a more efficient breather system and do NOT detonate the engine.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
