Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- Corvette: How to Replace Stock Shifter
Step by step instructions for do-it-yourselfers...
How-To: Install Short Shifter / Replace Stock Shifter
#142
Insulation time - this is pretty similar to MGW's videos (which are quite good). The C7 is very similar to the C6 in this respect.
I'll show you a few tips on application, though - they'll come in handy on the sections you have to put all the way down low.
This part is notoriously annoying. Peel back a small amount of the backing before shoving the piece under the torque tube:
Once the bottom is firmly affixed, peel back the rest of the cover:
Same goes for the side:
#144
This may have been answered already,
does this shifter cure the 1 -2 shift - I always feel as though the shift from 1 - 2 is a grinding shift. Somedays the shift is nice, somedays the shift feels forced
Thanks for the write up!
#149
Just placed my order today. From day one I was not a fan of the stock shifter. I felt it too long and going from 4th to 5th was an issue for me at top speed. (hit 3rd a few times). With 3000 miles on the car now, I am more comfortable with the stock shifter but still not totally happy so I just decided to make the move and seeing the relative ease of the installation. Will post a follow up after the install.
#150
#151
Just installed mine tonight - took 2 hrs, but I took my time with it. This shifter is WAY better than stock - spend the money and you won't regret it - no more missed 2 - 3 shift and it feels sturdy - much much more than stock. In fact, I thought stock was decent to begin with, but this is on a whole other level
#152
Got the shifter in the mail Tuesday. After dinner I decided to install. Went for a test drive. The shifts were 10X better. Felt much better making the 100 + shifts. No noise issues. I actually added some extra heat/sound sheets while I had the console apart. I highly recommend C7 owners to made this easy mod. You will be very happy with your car.
#153
Turn 12!
Do you notice any "2nd to 5th" issues with this new shifter? I know the stock one had some issues with this.
#155
If you have a convertible...
...you will need to remove the waterfall.
A couple extra steps are required to remove the console if you have a convertible...
Drop the top and then push the button to raise it back up so that the tonneau cover is pulled back.
Pop out and remove the two tabs on the back of the waterfall
Unscrew the two bolts on the top of the waterfall and lift waterfall straight up
Then, you can proceed to remove the console.
This took me a lot longer than the previously stated 2 or so hours to complete. I probably spent two hours trying to get the stock cover over the MGW Rubber Boot (raw fingers resulting too) - by far, the most difficult part.
#157
MGW install going well
MGW install going well so far! I'm done for the night. Will finish up tomorrow. Thnaks for this great thread Theta! With this and the MGW instructional videos All has gone quite smoothly.
Installed & Ready to put the layers back on!!
This is how I found this factory rubber cover It looks like it just flat wore out. 14000 miles. Hmmmm.
Flattman (08-21-2022)
