Adjustments for adding bigger tires?
Old 03-21-2014, 04:14 AM
Ronbear
Ronbear's Avatar
Default Adjustments for adding bigger tires?
Thinking about changing my base OEM tires to Z51 size tires. Will the computer need to be adjusted for Active Handling, Traction Control, etc?
Old 03-21-2014, 07:21 AM
savage
savage's Avatar
Default no
go taller/ shorter, or even the same front and back and your fine. but never go taller in front than the back without turning nannies off!
Old 03-21-2014, 07:54 AM
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
If you move from base wheels and tires to Z51 wheels and tires, the rolling diameter is the same so no change.
The only difference in base/Z51 is the 18/19" vs 19/20" wheel (the width of the tires are the same) but that difference in diameter is offset by a smaller profile tire on the Z51.
Old 03-21-2014, 03:37 PM
green2000
green2000's Avatar
To Adjustments for adding bigger tires?
Quick Reply: Adjustments for adding bigger tires?
