C7 performance brake pads including low dust
Brake Pads
What do you mean by "rotor friendly"? How much do they increase rotor wear over the stock pads when used for street use only and non aggressive driving. I don't need more brake I just want less dust.
Supporting Vendor
St. Jude Donor '11,'13
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Supporting Vendor
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call 216-780-8825 and we can recommend the compounds that will be perfect for your front and rear pads.
c6don (09-11-2016)
Brake Pads
Thanks for the info. Forum readers say you are a straight up vendor so I trust in what you are telling me. I will be ordering and installing the 1521 pads as soon as my C7 arrives. Its on its way next week from BG to Northern CA. by rail.
They do not increase rotor wear. They decrease rotor wear you will most likely get 2x the rotor life. The 1521 at normal driving will last 2-3 times longer than an oem pad.
Another C7 in Brentwood?? You're going to take away some of the attention I've been getting.
C7 Z51 (10-31-2017)
Pads
I'm in Northern California Brentwood, not O.J's old home town. If you are in North CA, I have already seen a few around town.
Email incoming since i can't find parts on the site directly.
#34
Supporting Vendor
Carbotech 1521 pad.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
F $170 R $173
F $170 R $173
