C7 tune Diablotune results!
#43
I emailed them the files with no response from anyone, so I called ...waited 10 minutes on hold and finally spoke to mike.
He advised me that they are about a week out on getting me a file..UGH
I wouldn't recommend buying the Diablo product till we see more success posted from the tool, seems that there are very few working correctly out of the box
Scott
Scott
#44
I just wouldn't recommend jumping at the special offer for next day shipping free as a way to separate you from 400.00..
#45
Apparently the tune in my car because of the few updates my car received was one diablo has not seen.
The reason the conversion file they sent me did not work is because I was saving to the intune drive directly from email!!my PC was only saving a file name.I had to save on PC first and change the attributes to the file to unblock.Then saved to the intune device, at that point the file loaded on the intune device and showed preparing,writing a few times and finally loaded to car successfully .....
One heads up here once the update file loaded itself it disappears from the intune directory,If I was told that from the beginning I would have known where to look a week ago...
WOW it was worth the wait.....Now I finally know why people need slicks!
The car wants to keep busting the tires loose.... leaps,jumps, throttle response increase....Very much a seat of the pants increase.....Good job Diablo!!!
The only thing I noticed is the skip shift is still in effect,it is supposed to be tuned out as per Mike on m7 cars???maybe because they did a quick conversion file to get me working...I don't know....
I guess I will have to wait a little longer for that feature to begin to work!!!
Vas was the tech support guy and did a great job!
#46
Ok Diablo got me a conversion within hrs when the intune did not work out of the box!
What's nice about the Diablosport products is that they add applications (updates) as new models come out. For example: you sell your C6, restore oem tune, buy a C7 install new can tune without purchasing another tuner.
#47
You can modify the tune and deactivate skip shift (cags) yourself, but it should of been deactivated from the can tune.
#49
Supporting Vendor
Glad to hear you are enjoying the tune
CAGS is hiding in a new spot on the C7, we'll get it added this week likely, along with the fan controls
#50
Mike,thanks your guy Vas was great!! But I have to tell you stuff gets misses with email support....If my support was handles via a phone call I would have been up a running a week earlier!! Please don't put me on the back burner as I would like it to be working 100 pct. I'm not sure I understand wasn't it you that stated that gags was auto tuned out earlier in this thread???or was it just my conversion file that is missing the deletion of cags???
Thanks again,
Ron
Thanks again,
Ron
#51
#52
Mike sent me the update Friday
worked 1st time...!
I installed the 91 octane tune...I know the diablo tune is hotter.
Really impressed with the results, 1/2 throttle in 1st gear(manual)
tires break loose....very nice....!
worth the money for sure
Scott
worked 1st time...!
Scott
#53
Supporting Vendor
but of course
awesome. That's what we like to hear
Enjoy!!!
Enjoy!!!
#55
Supporting Vendor
the cat back wont require any changes, but the headers will likely need a few tweaks from a CMR tuner. I havent seen a CAI yet, so tough to say if it needs MAF changes or not.
#57
Mike I been thinking of getting a tune for my Stingray..its a non z51.manual..i would like to have a better throttle response and a better punch off the line...can you give me a price a recommendation as to which one to get..in my small town in New Mexico best I can do is 91 octane..so Ill be using the 91 tune...can you also tell me the difference on the diablo vs the other tunes available (Pfadt tune).? thanks...
#58
Supporting Vendor
As for comparing to other tunes, I cant say as i dont have any experience with them, but we offer you a bunch of user adjustable parameters, including one we call throttle boost, which allows you to dial in more throttle response than the tunes offer out of the box if you so desire
#59
Do you have any AFR graphs on your tune, I would imagine your running more timing and less fuel to achieve these numbers. I would want to know it would be safe on a race track.
Does the C7 have Knock sensors to protect against detonation?
