Vengeance built turbo 2014 Direct Injection 5.3 Silverado Build..
Old 11-22-2013, 07:50 PM
0Ron@Vengeance Racing
Former Vendor
Ron@Vengeance Racing's Avatar
Default Vengeance built turbo 2014 Direct Injection 5.3 Silverado Build..
No explanation necessary for WHY we would build a turbocharged '14 Silverado, but it is worth noting that this truck shares many architectural, mechanical, and electrical features { Direct Inection/VVT/DOD/E92 ECU) with the '14 Stingray () and what we learned here will be applied to future projects...
Not that this is all about the tech, this truck flat out RUNS and the single Comp Oiless CT43 Billet Ball Bearing 67/70 Turbocharger made massive gains on the dyno and street on just 6psi, picking up over 152-rwhp and 169 lb-ft of torque!
Turbo System:
Comp Oiless CT43 Billet Ball Bearing 67/70 Turbo .96 AR
Tial MV-R 44mm Wastegate
Tial Q Blow Off Valve
All Stainless Steel hot side
All V-band connections
DEI Lava rock heat wrap
Bell 12 x 18 x 3 Intercooler core- VR custom fabricated endtanks
Complete Turbo System designed/fabricated/installed in house
Let's back up a second and start with how this truck started life. Our customer arrived at the shop with 430 miles on the odometer and was interested in having us fabricate a custom turbo system... Who were we to argue?! BUT, for the sake of science, we decided to dig into the truck in stock form first, then we tuned it, then we added a custom Comp Cams camshaft (Retaining VVT & DOD (for now)), then a stall converter, and then we finally built the turbo kit. Why? Science.
The results were in-line with our expectations... with the truck performing very well at each stage.
Stock: 314/340 vs. Tuned 318/357:
Tuned: 318/357 Tuned vs. Camshaft+Converter+Tune: 333/362
Camshaft+Converter+Tune: 333/362 vs. Turbo+Cam+Converter+Tune: 466/509
From the top:
Video:
Unfortunately, we ran out of fuel supply at 6psi but we'll be installing a new camshaft (deleting DOD) with an upgraded fuel pump lobe soon and then we will turn up the little 67/70 to see what it will do. Stay tuned!!!
Old 11-22-2013, 09:06 PM
BeaZt
BeaZt's Avatar
St. Jude Donor '14
Awesome work!
Old 11-22-2013, 09:54 PM
7LitreC5
Support Corvetteforum!
7LitreC5's Avatar
Very cool. Nice job on the fab work!
Old 11-22-2013, 11:37 PM
Redline Motorsports
Redline Motorsports's Avatar
Great job Ron! Looks like a fun work truck! LOL!
Howard
Old 11-23-2013, 10:18 AM
Bad95killer
Bad95killer's Avatar
As Usual, Great job all around guys and i'm excited about the upcoming stuff
Peace
Old 11-24-2013, 10:23 AM
yuri_Stingray
yuri_Stingray's Avatar
Old 11-24-2013, 11:10 AM
ChucksZ06
ChucksZ06's Avatar
The upgraded fuel pump lobe interests me. I was wondering if it is more volume, more pressure or both that you are looking for. I would think the mech pump is going to be the key for the forced induction mods. Is gm giving hints on this or diesel guys? I am curious as to the brainstorming behind modding the mech pump. I understand if you do not want to say. Great for us guys who work in a silverado and play in the vette. Thanks.
Old 11-24-2013, 03:18 PM
C7pimp
C7pimp's Avatar
That cam really jacks up the consistency of the power delivery.
I'd forego the cam with such a modest power increase and just run the turbo system. I'm not a cam fan anyways for a street car. No thank you.
Old 11-24-2013, 03:21 PM
C7pimp
C7pimp's Avatar
But if you can get a near 50% power increase on the stock fuel system, that's great.
If you can do the same with the Stingray, we are looking at a 600whp+ capable stock fuel system. That would be awesome. 600whp will satisfy the needs of almost anybody, excluding the insanely power hungry guys that like a 1000hp street car that they can never fully utilize anywhere.
Old 11-24-2013, 04:44 PM
carlrx7
carlrx7's Avatar
St. Jude Donor '08-'09
unless the fuel systems are exactly the same......
Old 11-24-2013, 04:49 PM
K B Vettin
K B Vettin's Avatar
that's a sick truck, great job!
Old 11-24-2013, 05:48 PM
Former Vendor
The truck has a smaller pump and smaller injectors...
600RWHP to 650RWHP should not be an issue for the Stingray.
Old 11-24-2013, 07:31 PM
BuddhaZ06
BuddhaZ06's Avatar
No cam in a street car? That's my favorite mod lol love the sound of a choppy idle! I put 4 different cams in my c5z dd
Old 11-27-2013, 07:34 AM
Former Vendor
I couldn't agree more
Old 11-27-2013, 08:21 AM
VIN666
VIN666's Avatar
NA, Cam and high comp = sexiest audio track known to man
Old 12-02-2013, 10:00 AM
Former Vendor
We are known for a few of these types of builds as well ... Our naturally aspirated 440 LSX makes 1059 HP and turns 9500rpm
Old 12-05-2013, 01:07 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
Nice work on the truck. That has be be one helluva sleeper.
FWIW, the 4.3 V6, 5.3 V8 and 6.2 V8 truck engines use the same high pressure fuel pump as the LT1. GM part # 12625817 is the part number for all 4 applications.
The injectors are different for the 4.3 and 5.3 engines in the trucks, but the 6.2 truck engine uses the same as the LT1
To Vengeance built turbo 2014 Direct Injection 5.3 Silverado Build..
Old 12-05-2013, 04:13 PM
ChucksZ06
ChucksZ06's Avatar
Nice to know. The torque rating on the 6.2 truck is almost identical to the lt1. I think those 2 engines are really close in construction. Any comments from those who have taken both apart?
Old 12-06-2013, 06:32 PM
smurfkiller
smurfkiller's Avatar
Old 12-13-2013, 05:25 PM
Former Vendor
Our customer dropped off the truck this week for additional upgrades while he is at sea (engineer on a submarine )
We will be installing a NON DOD camshaft with Comps larger fuel pump lobe and seeing what we can get out of this lil 5.3 in the coming weeks. Ill update this thread as progress is made.
Quick Reply: Vengeance built turbo 2014 Direct Injection 5.3 Silverado Build..
